Luminics H8 Fog Light Replacement Bulbs
gameday22
Florida
Had them on my Genny for a while now and they closely match the HID headlights in color, not the best pics from my phone but it show's how nice they look:
Luminics H8 5150k 35w - Mfg Part#: LW-H8T:
I picked mine up on Next Level Motoring for $27, $34 with shipping...they might be cheaper on other sites:
http://www.nlmotoring.com/Luminics-Ultra-White-H8-Bulbs-p/lw-h8t.htm
Fog lights are very expensive. The bulbs are not too bad, but it costs a fortune in gas driving around looking for fog.
Limited light output off these? ...Mine are definitely brighter then the stock lights were. What have you put in their place that is brighter? I'm all about increasing light output within the allowed wattage, not looking to melt my housing.....thanks :)
I believe mine were 5500K and there was noticably less light output vs stock bulbs. As shown on my old thread, I installed HID's, but the Genesis doesn't have the correct optics for HID's and the glare was brutal, so I took them out and put the OEM bulbs back in. In terms of an actual "upgrade from OEM" that will be pretty subject to many people, but I haven't found actual bulbs that would be up the proper lighting standards for myself. Doesn't mean they don't exist though.
:rolleyes: lol ....your killing me Mark :)...god it hurts to laugh that hard.....Thanks Scott for the info !!
+10 :d
fog lights are very expensive. The bulbs are not too bad, but it costs a fortune in gas driving around looking for fog.
Now that's a Mastercard moment...priceless!! We know what you meant, but you may want to check the weather forecast to save mpg's.
So any H8 bulb will work....incandescent, xenon, LED...?
Yes, as long as it's H8 it should have the same style of connector and you can use LED bulbs etc. That being said LED's in the fog lights are purely cosmetic, they don't have enough light output to effectively light the road. Do not exceed a power consumption more than 35w, as there have been reports of it melting the fog light housing.
+10
thx
Also, the temp should be around 5150K to get them to look like the HID projection lights (COLOR-WISE), correct? That's the goal I have.
Factory HID is 4300K for every auto for U.S. market, but HID is vastly different than Holagen in terms of comparing the same color temp against each other, so If you're trying to match the headlights (HID) then a color temp of 5000K-5500K should do.
+10
Thanks, Scott! Much appreciated.
Scottdk, I get that stock HID is 4300k from factory...how is it then that the light is brighter/shines further down the road on other manufacturers cars with HID (stock lighting)? Is it purely the projector at this point making all the difference in useable light?
To me it seems our lights don't reach out far enough for as bright as they are, I have measured mine at night for useable light with a couple of friends. On a road with zero street lights I marked the ground where the light first makes contact then again when they noted I was barely visible to them, and once again when they said I was out of view. I was wearing blue jeans and a light colored shirt. At 165ft they could barely make me out, and at 182ft I was not visible at all.
The lights have an incredible arc left/right that they illuminate but I'd think they should have more distance to them for being HID. My lights are stock HID as I have refrained from putting the new SYLVANIA SILVERSTAR D1S 5000K's in them until I get more information about the effect they may have on oncoming drivers, while more light would be nice I don't want to blind anyone.
Thanks for the feedback :)
I would believe that the HID lighting on vehicles equipped are very similar, but it's the optics that can differ car to car. The HID's in my Optima seem to illuminate the road farther then my Genesis, but I need to align my driver side head light up higher, but haven't had time. The optima lens is auto-leveling just like the Genesis, but not auto-cornering.
Regarding the OEM bulbs, I'd hate to replace them since the quality of a vehicle equipped with HID lighting, the bulbs are amazing in quality, if not the highest quality. Many owners of HID equipped vehicles will never even replace a bulb even over 10 years later, as long as the lens seal hasn't been compromised. I'm thinking the OEM bulbs are $150/each or more.
Check out this link to view instructions on how to aim the lights. I will skim the thread myself probably Friday before I adjust mine. My driver side is way too low IMO.
Here are instructions courtesy of BaywayRic -
Adjustment
Head Lamp Aiming Instructions <Mechanical aiming>
The head lamps should be aimed with the proper beam-setting equipment, and in accordance with the equipment manufacturer's instructions.
If there are any regulations pertinent to the aiming of head lamps in the area where the vehicle is to be used, adjust so as to meet those requirements.
Alternately turn the adjusting gear to adjust the head lamp aiming. If beam-setting equipment is not available, proceed as follows :
1.Inflate the tires to the specified pressure and remove any loads from the vehicle except the driver, spare tire, and tools.
2.The vehicle should be placed on a flat floor.
3.Draw vertical lines (Vertical lines passing through respective head lamp centers) and a horizontal line (Horizontal line passing through center of head lamps) on the screen.
4.With the head lamp and battery in normal condition, aim the head lamps so the brightest portion falls on the vertical lines.
Make vertical adjustments to the lower beam using the adjusting wheel.
A : Vertical adjustment(High/Low)
<AFLS aiming>
1.Using the scanner, do the following procedures. (Refer to the " Adaptive Front Lighting System")
(1)Download Parameter
(2)Erase the error code
(3)System Calibration
(4)Erase the error code
(5)Actuator Test
(6)Check the error code
2.Turn on the headlamp low & Hi beam after engine is running.
3.Adjust the "mechanical aiming".
Front Fog Lamp Aiming
The front fog lamps should be aimed as the same manner of the head lamps aiming.
With the front fog lamps and battery normal condition, aim the front fog lamps by turning the adjusting gear (A).
Head Lamp And Fog Lamp Aiming Point
1.Turn the low beam on with driver.
In case of bulb option, the Cut-off line should be projected in the allowable range (shaded region).
* In case of high beam, head lamp do not need aiming with proper beam-setting equipment.
2.Turn the low beam on with driver.
In case of HID option, the Cut-off line should be projected in the allowable range shown in the picture.
In case of equipping with the auto leveling device, set the initialization by using the diagnostic tool before aiming.
3.Turn the front fog lamp on with driver.
The cut-off line should be projected in the allowable range (shaded region)
More on halogen bulbs with blue tinted glass (Superwhites)
OK, So These Extra-White Bulbs Aren't The Best Choice For Maximizing My Headlamps' Performance. What Should I Get Instead?
For those who want the best possible performance from their headlamps and are more concerned with their ability to see rather than the appearance of their headlamps, the major bulb companies offer optimized bulbs without the light-stealing blue glass. Narva RangePower+50 and RangePower+30, GE Night Hawk, and Philips Vision Plus, and Osram Silver Star are the ones to get.
Wait a Minute, Earlier You Said Silver Star Bulbs Have Blue Glass!
It's a name game: Osram, the well-established German lampmaker, sells a line of automotive bulbs they call "Silver Star". These are Osram's top-of-the-range headlamp bulbs, equivalent to Narva RangePower+50, GE Night Hawk, Philips VisionPlus, and Tungsram Megalight Premium. They produce the maximum legal amount of light while staying within legal power consumption limits. They have colorless clear glass.
Osram bought the well-established American lampmaker Sylvania in the early 1990s, so Osram is now Sylvania's parent company. Sylvania also sells a line of automotive bulbs they call "Silver Star", but it's not the same product. The Sylvania Silver Stars have blue glass. Light output is of legal levels, but as with all blue-filtered bulbs, you do not get more light from them. The Sylvania SilverStar bulbs have a very short lifetime, because the filament is overdriven to get a legal amount of light despite the blue glass.
To get the best possible seeing performance at night, don't choose extra-white bulbs.
Daniel Stern Lighting (Daniel J. Stern, Proprietor)
http://www.danielsternlighting.com/tech/bulbs/blue/good/good.html
So the Silverstar's should actually be an improvement based on what I'm reading. I will get them done as soon as I have some downtime then take new measurements....Thanks for all the info /cheers :)
As long as they are the German made Osram Silver Star, yes...... If the bulb/package doesn't say "Osram" don't buy it.
Any of the bulbs below are great bulbs
Narva RangePower+50
RangePower+30
GE Night Hawk
Philips Vision Plus
Osram Silver Star
H1 Bulb Variant
Output Lumens
Life Hours
Standard (plain) 1550 lumens and 650 hrs
Long Life 1460 lumens and 1200 hrs
Plus+30
High Efficacy 1680 lumens and 400 hrs
Plus+50
Ultra High Efficacy 1750 lumens and 350 hrs
Blue glass
"Extra white" 1380 lumens and 250 hrs
