Gadfly
- Feb 3, 2009
again, 357hp on a GT30R is emberassing.
and no, that IS NOT the stock turbo. it spooled waaay too slow and it screamed like burning babies in hell. the stock turbo WOULD NOT sound like that.
i can't believe someone would ACTUALLY say "i think it's the stock turbo".
carlos nice
Well the only pictures of the car show a stock turbo, and the stock exhaust manifold with all the IC pipes all fabbed up and installed.. Also any turbo can and will sound like that though an open intake, or and intake pipe with a cone filter stuck on the end of it.
The intake pipe in the pictures is very short, and just has an airfilter on it.. Hence the sound...
Spooled too slow? you kidding? you see that dyno sheet?? It hit damn near peak torque at 2000rpm..... GT30R on a 2.0L motor is not going to spool at 2000 rpm...
Again.. I think that is the stock turbo with the intake, exhaust, and FMIC just like in the pictures, on some race gas with the boost turned up and a mild tune.
Here.. take a look at this old vid of my supra... short intakes, cone filters.. = turbo noise...
[ame="http://www.youtube.com/watch?v=k6JiUv8n0jc"]YouTube - Supra Dyno; 713rwhp / 601ft.lbs[/ame]
  Perosnally, I don't think you can call it weak becasue no one knows how much boost he is running. Since it appears to be using the stock housings, I doubt there have been any other efforts to boost VE, so it's not going to make a ton more power at the same boost levels without some decent boost in it. However, since no method of tuning is mentioned, I am willing to be it has stockish fuel and air metering, which means it will likely be running 20 ish psi. It's only a 2.0l motor folks.
		 ). maybe they just bolted it up to see what they could easily run.
