2015 Genesis LED strip as bright DRL instead of amber
Love it! Very nice and clean installation! Did you have to remove the bumper?
Great. I did the same. Good thing is that i have skinny hands.
Got around to doing the mod to my ‘15 HTRAC. I wasn’t expecting to do so much soldering so it took me a while. I tried my best to hide the wires too. All of the connections under the hood are soldered, shrink wrapped, and wrapped with electrical tape. I went the easy way out and used wire taps under the dash.
Thanks so much for the write up. I just hope my work stands the test of time.
Here’s some pics of the wire job.
Left side relays and a bit of a rats nest by the headlight.View attachment 21111
Wires going through the firewall
Right side headlight wiring after I put the air box back in.
Right side relays.View attachment 21114
Night time pic of the LEDs. Light switch in park in first pic and in off position in second pic. View attachment 21116
Curious, how long did the mod take you to complete?
It seems straight forward enough but I don't want to mess with my extended warranty... yet ;)
About 8 hours or so. Including figuring out where to run the wires and a couple do-overs with the connections. I have an extended warranty too. We’ll see if this bites me in the butt later.
Good point. Does anyone know if this will bite us in the end?
Question, I just picked up a 2015 lease return. Is it normal for the led strip to be illuminated in the parking light position? Just trying to see if the previous owner did something beneficial for me.
Yes, stock setting is it’s illuminated in dim mode when the light switch is in park position.
Is there such a thing as a quiet relay? I can hear the ones I installed clicking when my turn signal is on.
Mines are attached to the back of the headlight so I don't hear them at all.
These are supposedly quiet:
Morimoto XChange Switchback Drivers
I have 4 of them as my original intent was to use them to mimic oem blinker behavior which would turn off the LED DRL while the blinker was on but I decided not to do it as I prefer the DRL LED to stay on with the blinker. I have them sitting in my garage so I can check tomorrow or Sunday if they are quiet.
Hi there, thank you so much for valuable information.
Would it be possible to post a guide that allows to have fog LED strip always while ignition is on?
If I understand correctly, it should be a relatively easy mod.
Hi kozack, I am sorry I never got back to you with a wiring diagram. I will work on it today and get back to you shortly.
Absolutely amazing write up! Such a shame I wouldn't trust myself undertaking this level of electrical work. Would even be willing to pay for someone to complete this work. Hyundai should hire you! Fantastic work! Time for me to keep staring at your after shots.
I wish I'd had the OP around when I bought the KDM headlights for my Genesis sedan back in 2015.
Thank you Gents!
Great job. Sorry if this is a dumb question, but is it possible to tap a 12v acc line to the wire under the headlights? This would give the LED DRL’s constant power when the key is on. What am I missing?
OK I own a 2015 5.0 in the USA. I have the Amber lights as my DARL and blinker combo. Will this apply at all with my model?
Is there a fix or process to 1. Keep amber DRL/turn signal and 2. Increase Accent / Parking light intensity while keeping side marker light? Thanks
Yes, you can do that. Do you want both, amber DRL and increased parking light at the same time?
