30-Second OEM Wheel Cap Removal R-Spec
EXBMWGUY
Twin Cities, Minnesota
Recently I saw another post describing someone scratching their R-Spec 19" alloy trying to pry off the "H" wheel cap. Ouch!
So here is an easier and faster way.
First, if you want to keep your original wheel cap, move on because this procedure will destroy it.
Required: wood screw, screwdriver, hammer, pliers
1. Take a 1-2" wood screw and gently tap it into the center of the cap you want to remove.
2. Do 2-3 turns with the screwdriver.
3. Using the pliers, grasp the head of the screw and pull.
4. Put the new cap on.
5. Do the same thing 3 more times.
6. Reach for a beer.
The edge can also be padded/protected with black electrical tape then use a small flat screwdriver.
Just pop the cap out from the back of the wheel. I.E. take wheels off. The tire shop has to pop these off in order to get the new tires balanced. They snap right back in.
EXBMW - good advice also:)
I have the 17" base wheels, which I gather has the same wheel cap as the R-Spec wheels. I did exactly as you mentioned, and had Costco Tire Shop replace them when I got my tires rotated, and they gave me the OEM ones in a bag. I had to wait until first tire rotation, but no big deal.
Two small flathead screw drivers, use smallest one to pry just a bit of the cap out then use the other to pry it out more. Takes about 15 seconds a cap at most.
