ABS Light
morsegeek
Minneapolis, MN
When the ABS is active while driving, should the light illuminate in the dash? It was not completely clear to me from the manual.
The light turns on when I first start the car, as it should, but when driving on snowy roads and braking it does not illuminate even though I can feel the ABS activating. Is this normal or should the light be on when ABS in active operation?
It's normal for the light not to illuminate when it is active.
I believe the ABS light only stays on if there is a malfunction in the ABS system.
FYI: It does not come on in my 2003 Subaru but it did come on when ever activated in my 1989 Mercedes. I talked to a friend with a newer Mercedes and it does not come on when activated. Its my bet that on newer cars it only comes on when a malfunction occurs.
we had the abs and esc lights come on and took it to the dealer several times for this issue. After the 3rd trip they found a faulty sensor in the rear wheel area and that was the culprit. It hasn't been on since. The tech said the light will only come on if there is a problem.
