Eric@AMS
The AMS Hyundai Genesis stainless steel brake lines improve pedal feel and reduce the amount of time between applied pedal pressure and actual deceleration by reducing the expansion that is allowed by stock rubber flex lines. This provides a quicker pedal response and allows the driver to maintain consistent brake pressure and precision brake modulation.
Applications
• 09+ Hyundai Genesis 4 Cylinder Turbo Models
• Fits all USDM, JDM and European Models
$129.95
Click here to order
The AMS Hyundai Genesis Stainless Steel Clutch Line eliminates expansion giving you total control of your clutch. As the clutch pedal is depressed, the stock nylon hose expands making your clutch pedal feel less direct and at worst can make it difficult to shift. Add to the equation the age of the car and under hood heat and the effect can multiply. The AMS stainless braided hose will not expand with pressure or heat improving pedal feel and shifting. If you have a performance clutch with a stiffer pressure plate, do any sort of autocross or racing events, the AMS line is a must! Even if you just have the stock clutch, this hose will improve your pedal feel!
Features
• Improves shifting
• Improves pedal feel
• High quality construction for longevity and easy installation
Applications
• Hyundai Genesis 2009+ 4 cylinder Turbo Models
$39.95
Click here to order!
Applications
$129.95
Click here to order
Features
• Improves shifting
Applications
$39.95
