Adamant
- Jan 25, 2018
- Location
- Dallas, TX
- Genesis Model Year
- 2020
- Genesis G70
No rubbing issues yet. Hopefully that will continue to be the case once the car settles.Perfect timing. about to pull the trigger on GT-F and 20mm
What spacers did you get and any rubbing issues at all?
Pictures look great! Keep us posted on the rubbing. What spacers are you running?No rubbing issues yet. Hopefully that will continue to be the case once the car settles.
Dynofit.Pictures look great! Keep us posted on the rubbing. What spacers are you running?
Sorry about that, but I had a reduce the file sizes which took a bit. They’re all up now.No pics
Did you have to do anything to the studs? or was the 20mm deep enough to cover them?
No, it was deep enough. I don’t know how I missed it, but there is another thread that has the exact same title as this one. Several other people confirmed that they haven’t had any issues with the 20mm spacers as well.Did you have to do anything to the studs? or was the 20mm deep enough to cover them?
Thank youNo, it was deep enough. I don’t know how I missed it, but there is another thread that has the exact same title as this one. Several other people confirmed that they haven’t had any issues with the 20mm spacers as well.
Thanks for the update!Update for anyone looking to lower their G70 with Ark GT-F springs. My G70 is an AWD with the regular, non-adaptive suspension.
Appearance
Looks pretty fantastic with the gap removed!
Driving impressions
Like many have said, it's very similar to stock though there are a couple differences. I have a slow right hand merge close to my house that I go over everyday. There is a defect that runs across the road and has always caused my rear suspension to get a bit upset. With the Ark springs, that is gone. The second thing I've noticed is less body roll in corners. The comfort is still there but the car has a lower center of gravity now and feels a bit sharper.
Advertised drop (AWD)
1.1 front, 1.0 rear
Rocker panel to ground (extra drop)
Front 1 inch
Rear 1/2 inch
I drive 6 months in a winter climate, so ground/snow clearance is important. Based on the measurements, things should be just fine.
Installation
I had a shop do the install, which took a bit less then 4 hours and $300. No squeaks, groans or other noises.
Alignment
I will be measuring camber and toe myself to see if it's out much but based on what others have said, it may not require any adjustments.
Stock sway bars? Are you planning to upgrade them as well?Update for anyone looking to lower their G70 with Ark GT-F springs. My G70 is an AWD with the regular, non-adaptive suspension.
Appearance
Driving impressions
1.1 front, 1.0 rear
Front 1 inch
Rear 1/2 inch
Installation
Alignment
