Brake and Rotor Replacement Cost
Clarification: Because I was feeling a 'shudder' of sorts when braking from high speeds when slowing down on exit ramps, I wanted the brakes checked. Speaking to my technician after he drove the car, pulled the wheels and inspected the brake system, he found that the front pads, while needing a good cleaning, were just under 5/32 and the rotors required machining/turning due to relatively minor unevenness. New pads start at 12/32, and PA law requires replacement at 2/32. So although I still had considerable pad life left, probably enough to make to 50K miles or so, I chose to replace them while the rotor work was being done. While I am very gentle on my cars, I do live in the city, with lots of stop-and-go driving (which drives me crazy!). For comparison, my previous Lexus LS400 required front pad replacement at 55K miles (the service manager told me he never saw any customer get that many miles out of their original pads), while my Mercedes-Benz 500SL before that required front pad replacement at just under 30K miles. I personally have never heard of anyone getting 100+K miles out of front brake pads. That would be amazing!
I am at 112,000 miles on the original pads/rotors. Still very smooth braking. When I change I will go 100% OEM as they are obviously a solid product for this car. Though I am easy on brakes (not as much on the engine when I can) - I like to coast when possible
How many miles before getting a front brake job done on a Genesis 17?
Between 15,000 and 100,000. Depends on where you drive and how you drive.
About 1 month back the brakes started to make grinding sounds and 3 weeks later they sound really really bad and are worn and cutting into the rotors on both sides so will need to be replaced along with the rotors (I do rotors almost always instead of turning or cutting them as I dont find the work/value worth it). I had used Powerstop K5845 from Ebay and only aid $320ish for entire set.
So this mean I got about 4ish years out of the set and about 30,000 miles from the PowerStop with very little driving last year due to Covid (just about 5000). To me that's not that great as you can see others getting a lot more out of the OEM Sets.
Anyone know if this set will work with the 2012 3.8: 58101-3NA02 - Brake Pads - 2011-2014 Hyundai | hyundaiparts
There is a shortage of parts locally in PA so I cannot even get a set in time or at least not for the next 3+ weeks...
Shahhere
I cannot update the above post but noting that I put a lot of information in a consolidated Brake/Rotor thread:
Shahhere
