The TSB states that dealers are required to do it for cars in inventory before sale, so that could be.I asked them to test drive one of their Genesis Sedans off of their parking lot to see if it felt similar. My conclusion was that it felt worse than my carCould have been that they have done the fluid change on it and also left air in the brake lines. Either way, at this point I am happy with how my brakes feel.
If there is air in the brake lines, will the air eventually go away (or go into the reservoir, etc)?
When I first got my car back after the DOT-4 upgrade, the brake feel was clearly degraded from before, but it has noticeably improved since then. But I am not sure exactly how much it has improved, since I may have just got used to the new feel.Hey Mark, I doubt the Air will go away! it will remain, the Brake system is an airtight unit.. Bleeding is the Correct & Only way to get rid of Air in the system.
My dealer did not do the brake flush correctly, so I wish they had taken more time to do it right (and make sure no air in the brake lines). This adversely affected my brakes.How long should it take to replace the brake fluid? My dealer said it would take 90 minutes, added on to the time for the oil change and inspection which I was already there for - and so I didn't have another 90 minutes to wait so I scheduled the TSB for another time.
But they have me thinking about how long it takes them to perform service. This is the second time an oil change and inspection has taken so long - once I went in for oil change along and it was nearly as long (about 90 minutes) - are these times normal? and is 90 minutes for the brake fluid change normal?
Because of the location I have to wait there as opposed to dropping off, and I seem to waste alot of time sitting waiting.
Thank,
Brian
Suppose I told you it should only take 60 minutes (even though I am not saying that), what difference would that make to you? Are you going to start arguing with the Service Advisor/Manager?
Also, are you assuming that they can start work on your car as soon as you arrive? That is very unlikely even if you have a reservation.
I understand your frustration, but that is unrealistic. It is no different than a doctors office in that an appointment it is only an estimate, and in reality there is no way they can start every one on-time. They deliberately make sure there is always a little more scheduled than they can do, so they don't end up with slack time. There are always last second cancellations or no shows, and they don't want to get stuck with idle workers. It is part of the service business. If they were always able to start exactly on time, they would have double their prices.And by the way, I make a specific appointment for a specific time, and so yes, I do expect that they start on it fairly close to the time I bring it in since it is a 'will wait' appointment.
