Burger Motorsports JB4 high performance tuner for Genesis vehicles
Status
Not open for further replies.
Are you losing traction with RWD?
The Stinger guys reduce boost in the first 3 gears to help with traction!
Isn’t that a map 6 thing? Or if you set it does it work on every map?
I haven’t touched those setting at all. Cause I haven’t found anything to help me understand how they work lol
Well good for you. And what kind of heat were you dealing with?
I don't remember exactly but probably mid 70s
I think your car should run "much" faster anyway. Try Map 5 and see if it helps.
Just the JB4 and my fat 220lb ass behind the wheel. That’s all.
That’s impressive. I have intakes as well and best pass has been a 13.364
No wheel spin at all just a bit slow off the Line then boost comes on and I’m off.
That run was with the A/C on not that makes much difference.
Come drive my car for me 😂.
I’d think I would have a similar thing helping me in nv but I’ve also heard a lot about the speedway out here not being know for fast passes.
Well my run was just nice flat recently paved empty road out by the Mesa Airport.
I’m going to try to get some runs in in the morning tomorrow temps are supposed to be 78-80 around 7am.
Maybe it is bogging down at launch. Happens if your tires are too sticky!
How do the boost by gear values work? Is the entered value the boost below stock psi?
It sure if it is below stock or below the Map setting. But I think 1st gear is -5psi recommended.
So to you have to also enter the - symbol or just a plain value?
I heard back from Terry through email, he said everything looks good on log file for map 1, now he needs to see map 2 log. 😎
Had a chance to play with Map 2 yet?
I just drove to work for the night, I have the car in Map 2 but since it's the middle of the day I didn't open things up fully yet. I drive home at about 6:30 in the morning, which is the perfect time to have some fun as there are so few cars on the road at that time of the day. On my drive to work I did a few quick blasts in eco mode with my BMS Pedal Tuner in stage 3. This leads to the turbos spooling with very little throttle input, much fun was had by all!
Okay the boost by gear is phenomenal!!!! I’m super impatient so I just went to mess with it. No idea what actual times are but by lowering boost in only 1st gear by 4psi it produced the jb4 app to tell me 4.7 0-60. Not sure the accuracy of it but compared to it saying 5.1 before I could feel the difference it made for sure.
Don't rely on those numbers in app, they aren't accurate and are off +/- up to half a second.
Status
