Burger Motorsports JB4 high performance tuner for Genesis vehicles
Status
Not open for further replies.
I figured out how it was spinning up. I wasn’t at a complete stop and with the front tires rolling I think the car wont cut the throttle and just lit um up. I did it again today coming out of my subdivision. Got all kinds of sideways drifting up the street.
I’m in Vegas. Ya idk I’ll do some trouble shooting and if I can’t figure it out I’ll contact them. But I just tried a couple more runs and got it a little quicker. 12.79. I had a 12.38 but it was down hill 1.76 percent so that’s invalid lol
yea downhill just a bit of an advantage. 😊.
your a bit cooler in Vegas now in the mid 40’s and if it’s like the Phoenix Area the streets are a bit dusty at times.
Ya pretty much everything here that is open to actually run without traffic and flat is on the outskirts surrounded by desert lol so that could be hurting me off the line as well
im happy running map 2 and getting 0-60 4.55
4.77 was the quickest I got so far. I gotta get gas then I’ll try map 1&2 and see how traction is with those and see if somehow I get a quicker 0-60.
Buying this when I get mine I can't wait!
So in case everyone was wondering we can not run with the v10 Audi R8 lol. Rolled one today on map 3 with octane booster. He gave me the hit both times we ran and he just walked away. I knew it was going to be bad but want thinking it would be that bad haha
A friend of mine owns one, highly modified twin turbo, pushing around 1000whp. That thing is a monster! check out the license plate, though ;)
Ya when you start twin turboing those cars it’s gets insane. You can get them to like 2200 whp but it’s like 140k on top of the price of the car
Engine isn’t even out yet...how would anyone possibly know?
I know, but it seems to work with everything so far, it's not like a tune where it reprograms the ECU, so I'm assuming it will work with that new engine, just inquiring.
It will probably work with the new 2.5T also.
I'm waiting for the GV70 anyway, things might change by then.
ANY HELP! Just installed JB4 with fuel wires and mobile connect.
Changed plugs gapped at .022 installed all wiring
Took a test drive map 1 half to full throttle horrible backfires and sputtering. Switched to map 0 seems to run fine.
THIS IS WHAT I WAS AFRAID OF!
On the bright side plug install was alot easier than anticipated.
What other mods do you have?
Full evc exhaust & k&n panels, pedal tuner . I emailed Terry we will see.
Ya I couldn’t give you any thoughts on it. To me the cars tend to only be happy at cruising rpm or full throttle. Hopefully terry can shed some light on the issue for you
Were the backfires and sputtering dependent on you’re turbo psi? I had the same problem but I had already been using the jb4 for several months, I removed the jb4 and took it to the dealership and they swapped coil packs on cylinder 4 and 6, Havent put the jb4 back on since, still no problems, also is it giving you a CEL? If not try to get it to give you one, then check your jb4 app and read the codes and it’ll diagnose what is wrong. Best of luck!
For those of you in the 4.5 0-60 range running map 2...is that a 2.0 or the 3.3?
The 3.3T is 4.5 seconds stock. Others (inc myself) have bettered that.
Map 2 with min 93 octane should get you ~4.2 or 4.3 seconds (I think I got 4.1). On Map 3 with 99 octane (booster + 93) I got ~3.8 seconds.
4.5 is stock for the 3.3 but depending on DA some of us are in the low 5's/ high 4's stock. It doesnt look like the 2.0 can even hope of hitting that number, even on map 2
but your actual results will vary widely depending on DA
Status
