Burger Motorsports JB4 high performance tuner for Genesis vehicles
Status
Not open for further replies.
Is there a different way to update after you download the file to your phone?
I’m not the most tech savvy but I’ll give it a try
If you click on the file before you connect to the JB4 then it downloads it to the iPhone then once connected to the JB4 hit update the the green arrow on the upper right corner and choose the hex file from there.
Thank you for the help. That worked like a charm this morning
I set mine to 4 in first and 2 in second and pretty much smoked the tires 1st 2nd & 3rd. Never had that happen before
Dang really? I only have it happen when I don’t input values to hold boost.
yep. I was rolling to a stop and was almost stopped and engaging launch control and the front tires starting to roll like a true power brake and then the rear lit up and off the brake and 1,2,3 just smoking em.
Interesting. I guess just give it full power since you can manage to keep traction with it lol. I’m still on stock wheels and tires myself idk if you are or not
All stock JB4 of corse & 19’s RWD
I have no idea how you can keep tracking then on map 3 lol. I’m always spinning when I launch on 3
I was only on map 2 Before I had both first and second set to zero and it will just normally launch very little wheel spin just hooks up and goes I’ll keep playing with it see what I can do
Ya please let me know if you figure anything out. I just got my draggy and can’t seem to best a 4.8 0-60 but finally got the car under 13. I’ve been trying to mess with these settings a lot to see what I can come up with as far as traction but I have a feeling my altitude and the fact my tires are pretty much toast now are my down fall at this point.
I’ve been running 4.45 0-60 and 12.56 1/4 mile and that’s on map 3 and no boost reduction and very little wheel spin.
I wish I could get that lucky. I can’t find where the draggy says what my DA is. It shows my altitude at 2200 feet but can’t find the other one
What shift points are you using?
Trying to get the 1-2 shift at 5500-5600 and the 2-3 at 6100ish I have actually gotten a quicker 0-60 by .1 just leaving it in auto instead of manual
And now that I just checked the logs I’m no where near that. I hit my paddle at 5000 and it doesn’t shift until 6100 from 1st to 2nd Idk if that’s wheel spin screwing up my shift or what though.
Does I’d say downloading satellite onto to Draggy? If you skip that step it wont show the DA.
Yes it does and I let it load
Hmmm. Where are you located? Doubt it has anything to do with the satellites. May have to contact dragy.
Try to reset Dragy. Plug and unplug the charge cable.
I figured out how it was spinning up. I wasn’t at a complete stop and with the front tires rolling I think the car wont cut the throttle and just lit um up. I did it again today coming out of my subdivision. Got all kinds of sideways drifting up the street.
Status
