homeofstone
I think this post comes closest to explaining the "crushed filter" mystery.
On the 5.0, there is a filter post in the filter housing affixed to the engine and another post in the end cap which screws onto the fixed housing.
If the filter is not precisely aligned onto both posts - it will be crushed. Probably one should slide the filter onto the end cap post and then screw both components into the filter housing - with a small prayer that the other end of the filter perfectly aligns and slides onto the filter housing post.
On the 2015 5.0, at least, this process is somewhat facilitated by the fact that the filter is almost "square" -- i.e., it is 3" tall, and 3 5/16" in diameter. The taller the filter - obviously - the harder it is to align the filter on both posts.
All in all, it is a sorry design. If you had your car upside down on a bench, it would be one thing. But working on the floor, it's a bear. Maybe that's the reason, on my car, they hide the whole thing with two splash panels and lots of push pins.
*** I'm assuming from the relevant posts in the thread that the filter mounting procedure is about the same for the 4.6 and the 5.0. And, on my car, at least, no matter who makes the filter - that baby is gonna get crushed unless your aim is pretty good before cranking down the filter cap.
Canister oil filter systems are on many cars and some systems are much more complicated than the Hyundai. Use oem filters and there is little chance of a problem.
