Hi all, I found an installation video guide for installing a
dashcam in the G80. It is in Korean, but the visuals should be sufficient to follow along. He also installs a
dash cam with a side camera, which I don't think I have ever seen in the US.
I can confirm that the GV70 A pillar is constructed almost the same, except the clip holding the top of the A pillar is black instead of white, and is a bit harder to reach because the gap is a little smaller. After removing some of the rubber door trim, I used a plastic Scosche interior panel pry tool to pull the top edge of the A pillar off. There is a black clip holding the top of the panel to the A pillar, and tabs on both sides of the clip need to be pressed in order to release it. The gap at the top is too narrow for needle nose pliers, so I pushed one tab using the pry tool from the top, and while holding the panel away from the pillar to keep the first tab depressed, I pushed the other tab very carefully by wedging the pry tool from under the airbag. The panel then comes off freely.
I saw another Korean installation video that strongly recommended removing the A pillar and routing the
dash cam wires down the front of the A pillar. Routing the wires in the back of the A pillar by just removing the rubber seal can cause safety issues by obstructing the path of the airbag inside the A pillar.
I have not yet installed my
dashcam as I need to order some micro fuse taps. I would rather not just wrap bare wire around a fuse like the guy in the linked video does - seems a bit unsafe to me but I could be wrong. Curious to see if anyone manages to install a rear
dash cam as well. When it opens, the trunk adds about 5cm of distance from the inside roof of the car. I assume I will need to allow for about 5-6cm of extra cable length for the rear camera, but am worried the extra loop of wire might look a bit ugly.
