timothyarthur
- Jan 25, 2023
- Location
- Ontario
- Genesis Model Year
- 2023
- Genesis GV70
I really like how you set it up. What dash cam is that? And how did you keep the wire on the roof? Was there a plug in there?I don't want to see my dash cam...it's there and running "just in case". So I purposely put it on the other side. Below the cowl, I find it becomes a blind spot and is distracting, although I have my screen turn off about 5 seconds after the camera boots. Also don't want it super visible from the outside. I balanced height and as tight as possible to the cowl (ideal was tight to headliner, but then it was being blocked by the cowl) so after playing with the positioning, I found that was optimal spot. It's a bit off centre but the view is wide so the 4" off to one side makes little difference.
Sorry, not sure why the image keeps rotating 90 degrees each time I attach, but I give up trying to fix it.
I have also had great luck with Nextbase.I've had better than average luck with Nextbase ones. They aren't perfect, but they work for me.
Sorry for the delay. It is the Viofo A129 Plus Duo. Got it on sale during black friday for under CAD $200. This is my 2nd Viofo. Have had great success with them. They are a fraction of the price of some of the bigger names but they serve their purpose, which for me is a bit of an insurance policy, "just in case". Only viewed a couple of videos now and then on my old one, and they were always flawless. This one has wifi connection to download or view vids and make adjustments to the settings.I really like how you set it up. What dash cam is that? And how did you keep the wire on the roof? Was there a plug in there?
Mine is attached to rear trim of the hatch itself. I ran my wire from the headliner through one of the rubber articulated boots between the body and the hatch frame so I mitigated that issue. As a result, I could have also attached it to the glass without a loop but chose to attach to the trim instead.I have the same camera and setup. I let Best Buy install mine. My rear camera is also mounted to the rear trim. Makes it so no wire loop is needed like when you mount to the rear glass so the hatch can open.
Ok, confused...is this not GV70 forum? I don't know the GV80 but like I said, the way it's done on GV70, my cam is attached to the hatch, whether hatch trim or glass, no loop required to allow slack for when door is opened.No. They did it the way I wanted it. Camera does not move. otherwise you need enough slack to allow the hatch tobope. Also, mine is a GV80.
There is, but no need to do that on the GV80. The back does not slop as much as the GV70, so the camera is not in the way at all.O
I suspect, but not positive, the same could have been done in the GV80. There must be a rubber channel for wires and washer fluid from the main body (at the top) to rear hatch.
Okay, to each his or her own. I still would have run it to the hatch and have it completely clear of the opening when the hatch is open in order to minimize risk of it getting knocked accidentally and not notice that is not pointed correctly.There is, but no need to do that on the GV80. The back does not slop as much as the GV70, so the camera is not in the way at all.
Dealership installed it for meHas anyone tried hardwiring a dash cam into a GV70 yet? Wondering how to disassemble the A pillar area as it looks like it has a vent in it as well.
Looks interesting and an easy swap if the camera is solid quality
I have one in my Volvo and it's solidLooks interesting and an easy swap if the camera is solid quality
Do you have pics of it installed and of the app or captured video snippets? I didn’t find anything online if any real value when searching.I have one in my Volvo and it's solid
Ill send you someDo you have pics of it installed and of the app or captured video snippets? I didn’t find anything online if any real value when searching.
