Except, I don't think ours comes equipped with the built in dash cam. We have a forward facing camera in the front, but must be for other purposes because in the vids, you actually see a separate lens next to it that they refer to as the dash cam. We don't have that. So contrary to previous comments hoping they would "activate" the cameras, I don't think this is just a firmware/software issue...we actually do not have hardware in place to activate. Happy to be proven wrong here.Have you seen the website where they show using the built in cameras? It also combines with the GPS whis is really cool.!
I think we all know about that, however, it isn't something that we have in North America. Hence why I and many others are disappointed Genesis didn't give up that feature here.Have you seen the website where they show using the built in cameras? It also combines with the GPS whis is really cool.!
On a GV80, does the connector behind mirror provide an always on tap ? I am concerned about the always ON tap draining the battery. Where is the power control box on GV80 and how do you set it to avoid draining the battery if the dash cam is wired. The camera I am trying to install is AZDOME M550.Most dashcam hard wire kits come with two hot wires, one ground and a power control box. They wire up with one wire to an ignition hot (only on when ignition is on) to provide power to the camera when you start the car. The other is connected to an always on tap to provide power when the car is shut off (for parking monitor). The power control box has settings for voltage levels to shut off the always on tap when the battery gets to the preset. This keeps the camera from killing your battery when the vehicle is not running.
Do not know what camera you have or its requirements.
Same and doing the same thing. It's a hassle...
I don't want to see my dash cam...it's there and running "just in case". So I purposely put it on the other side. Below the cowl, I find it becomes a blind spot and is distracting, although I have my screen turn off about 5 seconds after the camera boots. Also don't want it super visible from the outside. I balanced height and as tight as possible to the cowl (ideal was tight to headliner, but then it was being blocked by the cowl) so after playing with the positioning, I found that was optimal spot. It's a bit off centre but the view is wide so the 4" off to one side makes little difference.I'm wondering how people have actually mounted their dash cams? I would prefer to install it right where the big plastic cowl is on the windshield that has the cameras, etc in it. I really don't want to put the camera below it or it is blocking my view. If I mount it too far over on the passenger side then it isn't centered...just curious if anyone has any pictures? My dashcam is on the way so I have to figure this out now I guess. One of the pictures of the camera I ordered shows exactly how I do NOT want to mount mine! The camera is a Vantrue E1, by the way...
Just be aware that dealer may unplug if they need to check anything on the car. Also, if Ring has any sort of parking mode, where it will record when it senses motion, bumps changes in pitch of the car even with car is off, I would verify that it also has function to detect if car battery voltage drops below a certain level and if so, cuts off any further power to the dash cam. If it's getting 12V constant off OBD port and it's running frequently when car is off, it could kill your battery. That's why I went with a wiring harness from my dash cam brand that has this built in, and you can choose 3 or 4 diff voltage levels. Plugged into two spare spots in the fuse box on drivers side dash, left shin level.I have pre ordered the new Ring dashcam. It uses the ODB 2 port which faces vertically down under the fuse box on the GV70 . Installation seems fairly easy but I’m not yet sure how it’ll look ! View attachment 51034View attachment 51034
Thanks - that's exactly what I was looking for - a picture of a dashcam mounted to the side where I was thinking of putting it! I think that's the sweet spot!I'm wondering how people have actually mounted their dash cams? I would prefer to install it right where the big plastic cowl is on the windshield that has the cameras, etc in it. I really don't want to put the camera below it or it is blocking my view. If I mount it too far over on the passenger side then it isn't centered...just curious if anyone has any pictures? My dashcam is on the way so I have to figure this out now I guess. One of the pictures of the camera I ordered shows exactly how I do NOT want to mount mine! The camera is a Vantrue E1, by the way...
I considered the Ring dashcam but they won't sell it in Canada...I have pre ordered the new Ring dashcam. It uses the ODB 2 port which faces vertically down under the fuse box on the GV70 . Installation seems fairly easy but I’m not yet sure how it’ll look ! View attachment 51034View attachment 51034
Good to know. I've bought the adapter but still haven't gotten a dash cam as yet. Can you please show your installation set up.
X2. Also would love to see any video showing the opening of the Mirror back! (Apologies if I missed it, I'll scroll back in the posts and check YT)..Good to know. I've bought the adapter but still haven't gotten a dash cam as yet. Can you please show your installation set up.
Sure, I'll take some pictures when it's light out on the weekend.Good to know. I've bought the adapter but still haven't gotten a dash cam as yet. Can you please show your installation set up.
