Door lock problem
drjay9051
2009 Genesis sedan. Changed out battery in the key fob.
No problem unlocking with remote or start up. Problem is as follows:
I cannot unlock doors by pushing the button on the door handle. I can lock and unlock from inside but cannot enter unless I use remote.
Manual was of no help. I tried the setting section in the DIS but no help either.
Any idea as to how I "reset" the lock/unlock button ?
Thanks
Can you lock the doors using the door handle and can you unlock the trunk with the trunk button?
Trunk not a problem. I can use remote,switch on driver door or button located under edge of trunk on right side.
I cannot get the door handle to lock or unlock from the outside. The inside control is fine.
I suppose I could live with it but curious if it is a defect or a simple reset issue?
If defect covered by warranty? I did find a short thread related to bad door lock but not much help and certainly no fix was suggested.
I'll venture to say that if the passenger door button locks/unlocks the car, then you have a bad driver's door button. I suppose you could force a complete reboot by disconnecting the battery for a time to ensure it's not something really odd, but switches do go bad and all the more when used very frequently.
did you find a solution to the button not unlocking/locking?
