Easy to change color of light bulbs in 2011 Genesis?
You will be very happy with an HID upgrade. When I installed one side, I lit it up and compared it to the stock halogen. It made the halogen appear as if it were a 6 volt light, like something was wrong with it.
Look at the attached pic. You can see the beam pattern on my garage door. The front of the car is only 2 feet from the door. The left is the HID and the right is the stock halogen. Not only is the HID light output white, the beam pattern is so much larger. If you need help with it send me a PM and I will assist you.
HIDs require more power to start up, but less after they are up and running. The kit worked fine connected directly to the stock headlight socket, but I added a relay harness after the install. There was no noticible difference when I added the relay harness.
Automobile/motorcycle style HID's need a projector style luminaire.
Period.
What you have, if you have halogen headlights, are reflector-style luminaires.
If you put an HID bulb in a reflector style luminaire all you will achieve is very bright scattered light. As the driver or rider, you will love it.
As an oncoming vehicle, you will curse it.
This was mentioned in another thread - HIDs are designed and intended to be used in a lensed method that allows better aiming of the light beam. Placing a HID bulb in an enclosure designed for halogens will be GREAT for you, the driver, but blinding to oncoming traffic. The end result is putting a wonderfully bright light in a fixture that then scatters the beam and produces glare to those drivers approaching you. I'm not saying it's good or bad. I have the same issue with my motorcyle. I can put HIDs in it (dual beam 55/65 bulbs currently) and I'll get a helluva light outpout, but the reflector behind the bulb scatters it more and blinds oncoming drivers).
If you own a Genny with the tech HIDs it's VERY apparent that this is the case. The HIDs do NOT blind oncoming drivers (they are for low beam) and their pattern is very defined not to do so. They even articulate with the turn of the car and the elevation of the nose. Very cool indeed.
And this is something to consider, not that I care one way or the other:
"Update: May 3, 2007:
NHTSA Cracks Down on Aftermarket HID Conversion Kits
The National Highway Traffic Safety Administration (NHTSA) is targeting high-intensity discharge (HID) conversion kits for enforcement actions. NHTSA has concluded that it is impossible to produce HID conversion kits (converting a halogen system to HID) that would be compliant with the federal lighting standard, Federal Motor Vehicle Safety Standard (FMVSS) No. 108. The noncompliant kits frequently include a HID bulb, a ballast, an igniter, a relay and wiring harness adapters. The NHTSA believes this equipment presents a safety risk to the public since the kits can be expected to produce excessive glare to oncoming motorists. In one investigation, the NHTSA found that an HID conversion headlamp exceeded the maximum allowable candlepower by over 800%.
Under FMVSS No. 108 Section S7.7 (replaceable light sources), each replaceable light source for headlamps must be designed to conform to the dimensions and electrical specifications for the headlamp source it is intended to replace. For example, if an HID kit is marketed as replacing an H1 light source, then it must match the H1's wire coil filament size and location, the electrical connector size and location and the ballast design for use with an H1 light source (which is impossible since there is no ballast). Consequently, companies that are manufacturing HID light sources (e.g., D1S, D1R, D2S, D2R, 9500, etc.) with incandescent light source bases (e.g., H1, H3, H7, H8, H9, H11, H13, HB1, HB2, HB3, HB4, HB5, etc.) should be aware that this light source design would not be one that conforms to FMVSS No. 108, and could not be imported and sold in the United States without violating Federal law. (The importer is treated as the manufacturer and subject to the same fines and penalties that apply to a domestic manufacturer.)
NHTSA has also determined that a commonly used disclaimer "for off-road use only" has no legal meaning and is not recognized by the agency as the manufacturer, importer and retailer are not in a position to control use once a product has been sold. Any equipment offered for sale which is covered by FMVSS No. 108 (headlamps, taillamps, side markers, etc.) must comply with the standard."
Anyways, for what it's worth.
I'm going to buy from DDM, but I have a few questions...do I need to buy JUST the kit, or do I need to also buy the harness, error eliminator, etc.??
Thanks in advance for help!
You do not need the harness or error code eliminator, but you can run the harness if you want. There are no bulb out indicators on our cars.
Period.
QUOTE]
The halogen equipped Genny's have a projector for the low beam. It may be a projector designed for a halogen light bulb, but it is a projector which seems to work fairly well with the aftermarket kits.
Either way a proper HID projector seems to be a better option. At this point I wish I would have purchased the tech package over the premium and we would not be having this discussion, but it is too late for me.
I have contacted Black Flame Customs about retro fitting proper HID projectors into my headlights so I will have proper HID lighting in my Genny. I will report back on the cost.
Makes me want to have one of the beams retrofitted on my motorcycle too.
I've been reading that 5000K light is still yellow-ish in color, and can be mistaken for simple halogen lights. Is this true? Should I go for 6000k?
I know that factory HIDs are only 4300, and my old Acura with 4300K still looked white-ish/blue-ish. Will 5000K be white/blue light...or white/yellow? I plan to buy the ones from DDM Tuning.
Depends on the brand, but typically 5000K is very white. 4300K (OEM) is very white with a slight yellow contrast/hue and has the most light output of any color temp HID.
Here are some really good comparison pics of 4300K Vs 6000K Vs 5000K that I took using my headlights that I retrofitted on my own
4300K on top 6000K on bottom (HID projector VS HID kit in Reflector)
And here is the same projector with a 5000K bulb:
These pics should clearly show the difference in color. I HIGHLY suggest a 5000K bulb if you are going HID route. I also suggest a proper HID projector because of the step in the center that lots of people don't seem to understand, as well as the different properties of the reflector bowl in the projector.
So if I don't retrofit my lights...what major differences will I notice?
You will have flat cut-offs (not the step as in the pic above). You will also have more limited side visibility and "hot spots" of light in front of the car (also called pencil beams). Some halogen projectors take kits better than others but the first 2 things I listed will hold true here
I'm toying around with the projectors on my 12' -- things to note.
ECE cutoff | Major plus here.
D1S bulb | Major drawback here.
very nice circuitry, design on the LED... Hunting for a clear lens MOD ZKW might do the trick depending on the spacing... and possible slight shield modification.
Oh, not to worry... I'm going to buy a set of ballasts and pig tails convert them over to D2S to fit a set of Osram CBI I have sitting around...
Will the projector accept D2S? Did you mean D2S? D2R are for reflectors....
If the projector will accept D2S that will be good news since I have 2 sets of them laying around my house now....
ah yes -- I meant D2S sorry. The projector will accept it, it mounts right up however you'll need to be creative with the mounting as there is no clip to hold it in.
Standby headlight baking commences tomorrow evening.
On standby until tomorrow night. I'll have to fab up something then because I'm going to be running D2S instantly. Please keep me updated!!
