Flashing directional turn lights on dash
jimd
I had a long day driving and at around 600 miles I had a flash of lights on the dash display. By the time I looked down every thing was normal, so I was more aware of it and in about 5 minutes it happened again and this time I saw that it was both turn signal lights flash 2 twice. Then nothing happened for about an hour and then it did it again. Both lights together flashed twice.
I drove for another 200 miles and nothing happened.
I don't know if it was an electrical malfunction or if it is a problem code. Does anyone have any ideas? Does the Gen use the turn signal lights for computer codes?
This is on a V6 base model.
Thanks for any input.
Sounds like a connection with the hazard button. What happens when you push it and push it again?
I don't know. I never tried it and I can't for awhile as it is St Louis and I'm at Lake of the Ozarks. I guess it is possible, but I have driven over some pretty rough roads and it never happened before. I'll check with the dealer when I next go in.
Thanks for the reply.
