FS: Festoon Bulbs for License, Glove, Trunk, ONLY $4.99
Diode Dynamics
St. Louis, MO
36mm Double 1 Watt LED Bulbs
NOT IN STOCK YET!!! WILL BE IN STOCK JANUARY 5TH.
This will fit wonderfully as a replacement in your trunk lights, glove box, and license plate lights. For a total conversion, you'll need five. STOP PAYING HIGH PRICES! You won't find better prices on your LED bulbs than Diode Dynamics! :)
This bulb is a 36mm festoon bulb, but can fit in varying applications. It is made up of two terminals of high durability with double 1 watt LEDs in the middle, in a durable metal case. You will not find a brighter LED bulb for this application! A load resistor is embedded to prevent blowing the LED from voltage surge, and a diode is implanted to protect the LED from reverse polarity. The LED is wired for 12v operation, the kind found on all vehicles.
Included in your order is ONE BULB.
CLICK HERE TO SEE MORE PICTURES AND TO ORDER
EDIT: TYPO IN TITLE, PRICE IS $6.99. STILL A DEAL!! MODS PLEASE FIX!
Thank you!
Paul
Diode Dynamics
Looks great!
For the lighting gurus, will the 36MM require some "bracket bending?"
Switched to a little bit of a different model after talking to some of my suppliers about which one is brighter. This is it! :)
Looks great!
yes you will have to bend both contacts a little, but not much. Be sure to bend the solid contact a little more than the contact with the small opening. Once you get them in they fit very tight and secure.
Hey all Can we get a list of needed bulbs to make all the needed mods.
I want to order all, but do not want to miss anything.
