G80 Sport - discoloration of the dark chrome trim around the doors
My 2021 G70 has this problem. My car has never been through a car wash and I do not use any kind of soap to clean it. Just water. I take immaculate care of the car, and I’m retired so it sits in my garage most of the time. It only has 21,000 miles on it.
The car has four months left on a lease so I’m not going to try to fix it. There is a very good chance I will lease another one. Sure would be nice if they have fixed the problem.
Been a lurker for a long time, but recently been giving some love to my 2018 Genesis G80 Sport after buying it used last year. I wanted to share my results to hopefully help out others.
Last week, I polished out the whole car, and yesterday I tackled the window trim. I had them replaced last year under the 5year/60000 used car warranty by the dealer for free. The trim along with the rest of the car was coated with tuetlewax graphene flex spray wax. Within a few months they were already showing watersports and a year and 4 months after in Houston weather, they were looking pretty rough, especially along the driver's side front and rear window. The c-pillar twins were doing pretty good with light waterspots.
As some before recommended, it just took some brasso, 1.5 hours of elbow grease, and some microfiber towels to get everything back to shiny. See attached photos (screenshots from video since I can't upload video. Don't judge my b-pillar wrap, they were severely scratched beyond polishing when I purchased the car so I wrapped it myself).
Very happy with the results, yes the trim is a little lighter, but when comparing to my mostly pristine c pillar trim, I didn't notice a huge difference, just a tinge lighter in the sunlight. I protected them again with the tuetlewax flex spray wax, which I'm hoping will help because the underlying trim surface isn't as sensitive as the factory dark finish coating.
Some tips for those wanting to try this on their own discolored trim:
1. Tape off the paint around the trim. Don't worry too much about the brasso polish getting into the rubber around the trim because it wipes of pretty easily and doesn't stain (at least in the few hours that it sat on my car). I just gave the car a wash after, giving special care to the trim areas with a detailing brush to get into the rubber moulding. I would highly recommend you do the same.
2. Use lots of brasso. You need a good layer of brasso in between the towel and the trim. Just having some brasso absorbed into the microfiber towel didn't do too much for me. The towel should glide on the surface with the help of brasso. This makes everything come off much quicker. It also helps to keep a spray bottle of water and lightly mist the towel every few applications of the brasso.
3. Hit the trim from all angles. Once you get the discoloration and waterspots off, you have to commit and get to the bare aluminum because otherwise you are left with areas that are darker than others. Look at the trim from every angle in good lighting to make sure you're getting to the base layer.
I hope this was helpful, I'll try and answer any questions in a timely manner.
Heyoo I ended up wrapping the b and c pillars too by myself. Got a custom g80 trim kit from this website and it looks great! Looking to do the top rails too later on.
So I have an update on my trim. I spoke with the dealership parts dept., and it was ordered as well as a driver side seat cover. 👍🏻 The driver side seat was showing brown wear thru it after less than $40,000 highway miles.
My drivers side is starting to show cracks through as well. What is this seat cover? Oem and specifically made for the 2018 g80S? Just goes over the regular seat?
I've had all of the exterior window trim replaced twice on my 2018 G80 3.3T sport. All car windows except windshield had tinted film installed at delivery on the interior side of the window (including the rear "portal" windows). There is no need/reason to remove the window tinting or window to install the new window trim.
Your dealer messed up. Tell them to put the car back to how you left it with them.
Correction to the above comment ,,,,,, Your 2 rear quarter glass windows come with the window trim already sealed to the window, in order to replace the trim they have to replace the rear quarter glasses- they bolt in with a ribbon tape sealant which should be water tested after installation. Prior Auto Glass shop owner.
