G80 Sport Oil Change 3.3T Turbo
I spoke with the service department at my dealer (Twin City Genesis-Alcoa TN) last week. They were unsure about what the "spec" was for the G80 Sport (3.3L TT). They have been using a Synthetic blend in others G80 Sport. I'll continue doing my own oil changes and use Mobil 1 Full Synthetic 5W30.
I had the same issue. The service manager at Keffer Hyundai didn't know what type of oil was specified for this engine, so they default to a synthetic blend. The reason that ANY turbo engine should only run synthetic has to do with the heat of the turbo bearings and shafts. Higher heat will de stabilize the blend vesus a full syn and expose the bearings to pre mature failure. A full syn also dissipates heat faster than anything else.
Show them the ACEA A5 spec in the owners manual. Usually that means a full synthetic 5W-30.
This is the same problem SAAB had. They put semi-synthetic in their turbocharged engines and mandated a 10,000 mile change interval. After a few short years, the engines had coke build-up along with burned out turbos, resulting in a warranty extension to 8 years. They quickly moved to full synthetic with a 5,000 mile change interval. I can't imagine the 3.3TT running any cooler.
I took my G80 Sport in for an oil change. They wanted to put conventional oil in, which I objected too. They finally agreed to use synthetic. According to owners manual it takes
7.29 quarts for a change. They only show 6 quarts on itemized bill. Anybody know for sure how many quarts for a 3.3T twin turbo V6?
GRK
2018 G80 Sport
7 1/2 if you get all the old oil out.
Hey, Mark 888, sounds like you need to waste your money on a beemer
Mark_888 used to be a very active member of this forum but last time he posted here was around June/2018. You have resuscitated a year old thread.
I do all of my own oil changes. I've done it 4 times on my 2018 G80 3.3TT Sport. I consistently drain/fill 7 qts. My procedure is warm engine to normal operating temperature (based on vehicle temperature gauge). I jack up driver front side about 1 foot to give me room to get under car. I let oil drain for 45-> 60 minutes until there is no more oil dripping. I check the oil level regularly after change and ensure level is right at high/full mark on dipstick. I also/always change the oil filter. Per page 8-6 of the Owners Manual the oil CAPACITY is 7.29 US qt (6.9L for our friends North of U.S. border ;). Short of tearing down engine you're never going to get ALL of the oil out.
Manual does not explicitly specify full/partial synthetic, just ACEA A5. Footnote 3 states "If the ACEA A5 engine oil is not available in your country, you are able to use ACEA B5 or API SN & ILSAC GF-5 ". I don't believe you can get 5w/30 ACEA A5 certified conventional/dinosaur oil in the U.S. anymore. I run Mobil 1 Full synthetic 5w/30.
Pennzoil Ultra Platinum fits the bills when it comes to ACEA B5, plus it keeps the engine cleaner it seems.
21544
My closest Genesis/Hyundai dealer also has Honda and Acura dealerships, and has standardized the 5w-30 across all of their dealerships to a Honda synthetic blend. It isn't my first choice, but it does meet the ISLAC GF-5 spec.
I don't know how much the label on the can means. Unless Honda has a refinery, it is re-labeled and perhaps your favorite brand. If it meets the spec, it meets the spec and will perform as needed. I could never tell any difference between brands, never had oil related issues.
I would dump Mobil1 if I were you, I did, when I got my Chrysler 200, Mobil1 has only a few basic certifications, not even had the one for Chrysler, so I switched to Castrol GTX, now I'm gonna switch to Pennzoil, to see if it keeps it cleaner. I still have the 200, and I do my own oil changes every 5k, and it always come out black and stinky, we'll see if Pennzoil comes out cleaner.
Ok let's do a quick check in with the Project Farm guy and see how multiple oil brands tested out. ......... I started the vid at the final summary of his half year long or so testing.
  • Like
Reactions: EdP
Thanks for that.
It still comes down to "what do I need for my purpose" but there were no really bad ones there. This gives some idea of expectations.
Interpretation of the numbers is tricky. Would the best oil for someone driving the interstates for 50k a year be the best for someone driving 1 mile to the grocery store in the winter?
Engine oil has 3 basic jobs, Lubricate, Cool and CLEAN. If an oil spends 5,000 miles in any engine and comes out looking Like it was just put in, it is NOT doing its job and I would never use it again. As a retired fleet mechanic I would never let the lowest paid, least experienced people change the oil on my vehicles in stealerships. Mobil 1 5w30 EP has the cred for the 3.3TT. Iv'e used Mobil 1 for 30+ years with over one million miles of personal miles with absolutely 0 oil related engine problems or issues. Those miles include Cars, trucks, motorcycles, tractors, lawnmowers, snowblowers and one 4 stroke snowmobile. Mobil 1 is very adequate in my opinion.
2013 Sonata 2.0
A few years back, a Hyundai Canada TSB stated the recommendation is to use 5w-40 for the turbos. My Sonata 2.0 had 160K miles on it and still pulled like the day I bought it, new. Looking to use the same in my G70, once I figure out how much to put in. :)
