Houston, TX Genesis Sevice rates from a local dealer
FIAT
Hi I know we all have talked and wondered about what others are paying for keeping our Genesis running great. Below are the rates listed by a local dealer.
If any of you would like to comment how they stack up to what you have paid it will give us all knowledge of where we may be getting ripped off. One item I see that sticks out as being over priced is the cabin air filter @ $69.95 is way over priced.
Enjoy,
Fiat
Service Description Estimated Price
3750, 11250, 18750, 26250, 33750, 41250, 48750, 56250 miles
# New Genuine Hyundai Oil Filter
# Vavoline 5w20 oil
# 27 Point Inspection
# Check and Adjust Tire Pressure
$29.95
premium 3750,11250,18750,26250,33750,41250,48750,56250 miles
# Vavoline 5w20 oil (with synthetic blend oil)
# Top Off Fluids
# Tire road Hazard Warranty and Roadside
# Assistance
$49.95
7500, 22500, 37500, 52500 mile service
# Vavoline 5w20 oil
# Rotate Tires
$59.95
premium 7500,22500,37500,52500 mile service
# Vavoline 5w20 oil (with synthetic blend)
# Rotate Tires
# Top Off Fluids
# Tire Road Hazard Warranty and Roadside
# Assistance
$84.95
15,000, 45,000, 75,000 mile service
# New Genuine Hyundai oil Filter
# Vavoline 5w20 oil
# Rotate Tires
# Battery Cleaning and Charging Test
# Replace Engine Air Filter w/Genuine Hyundai Filter
# Lube Chasis
# Inspect Transaxle Fluids
# Inspect Brake Hoses and Lines
# Inspect Brake Pads, Calipers and Rotors
# Inspect Exhaust Pipe and Muffler
# Inspect All Suspension Bolts
# Inspect Steering Gear Box, Linkage
# Inspect Upper and Lower Arms
# Inspect Driveshafts and Boots
# Inspect A/C Refrigerant
$149.95
premium 15000,45000,75000 mile service
# Vavoline 5w20 oil
# Rotate Tires
# Battery Cleaning Service and Charging
# Test
# Hyundai Filter
# Replace Wiper Blades
# Lube Chasis
# Inspect and Lube Door Hinges
# Assistance
$209.95
30,000, 90,000 mile service
# Vavoline 5w20 oil
# Rotate and Balance Tires
# Test
# Hyundai Filter
# Coolant Flush
# Brake Fluid Flush
# Lube Chasis
$369.95
premium 30,000, 90,000 mile service
# Vavoline 5w20 oil with Synthetic Oil Blend
# Test
# Hyundai Filter
# Coolant Flush
# Brake Fluid Flush
# Lube Chasis
# Assistance
$474.95
60000 mile service please click dropdown for detail
# Genuine Hyundai Oil Filter and 5w20 Oil
# Tire Rotation and Balance
# Coolant Flush
# Brake Fluid Flush
# Transmission Fluid Service including Genuine Hyundai Transmission Oil
# Replace Genuine Hyundai Spark Plugs
# Replace Genuine Hyundai Engine Air Filter
# Lube Chasis
# Inspect Drive Belts
# Inspect Timing Belt (if applicable)
# Inspect Front and Rear Brake Linings
# Inspect all Steering Linkage and Bolts
# Inspect Upper and Lower Control Arms
# Inspect Power Steering Pump and Hoses
Please note 4 cylinder $674.95
$774.94
premium 60,000 mile service please click dropdown for detail
# Vavoline 5w20 (with Synthetic Blend Oil)
# Coolant Flush
# Brake Fluid Flush
# Clean and Adjust Rear Brakes
# Lube Chasis
# Assistance
Please note 4 cylinder $789.95
$894.95
check engine light on
Check Engine Light Diagnosis Including a Copy of the Cause as well as an Accurate Estimate of Repairs
$105.00
balance tires
Balance Tires by Hunter Computerized Balancer
$49.95
rotate tires
Rotate Tires
$21.95
4 wheel alignment
4 Wheel Alignment
$89.95
front brake job
Replace Genuine Hyundai Front Brake Pads and Resurface Rotors
$219.95
rear brake job
Replace Genuine Hyundai rear brake pads or shoes and turn rotors or drums.
$219.95
battery service
Check Battery and Charging System by Certified Hyundai Technician
$14.95
replace a/c cabin air filter
Replace Genuine Hyundai A/C Cabin Air Filter
$69.95
replace wiper blades
# Replace Genuine Hyundai Windshield Wiper Blades
# Fill Washer Fluid
$19.90
replace engine air filter
# Replace Worn Engine with New Genuine Hyundai Air Filter
$24.00
cooling system flush
# Drain Old Coolant
# Flush Cooling System with MOC Coolant Cleaner
# Refill Coolant with Genuine Hyundai Coolant
# Check all Cooling Hoses and Belts
$109.95
brake fluid flush
# Drain all Brake Fluids from System
# Flush Bake System with MOC Brake Fluid Cleaner
# Refill Brake Fluid System with Geunine Hyundai Brake Fluid
# Bleed Brake System
# Inspect all Brake Lines
$109.95
throttle body cleaning
# Throttle body cleaning
# Flush injectors
# Inspect injector seals
$89.95
transmission flush
# Drain Existing Transmission Fluid
# Flush Transmission Fluid System with MOC Transmission Cleaner
# Refill Transmission with Genuine Hyundai SPIII Transmission Fluid
# Check all Transmission Lines
$179.95
power steering flush
# Drain existing Power Steering Fluid
# Flush Power Steering System with MOC Power Steering Cleaner
# Fill System with Genuine Power Steering Fluid
$109.95
recommended maintanence
Recommended Maintanence per Hyundai Owners Manual by Certified Hyundai Technician
1 year state inspection
1 Year Texas State Inspection
$39.95
recall
# Hyundai Recall
wash and vacuum vehicle
# Wash
# Vacuum Vehicle
I'm glad my dealer does not charge me for all that stuff thats not needed.
What in the world is "Tire Road Hazard Warranty and Roadside Assistance"? You pay for that? Roadside assistance comes with the car, and tire road hazard should come from when you bought the car, not every so many miles.
What about those Transmissions Services using genuine Hyundai Transmission Fluid?
What about their Transmission Flush with MOC transmission cleaner (this is a NO NO) and Refill Transmission with Genuine Hyundai SPIII Transmission Fluid (also a NO NO. The Aisin transmission in the 3.8 and the ZF transmission in the 4.6 do not call for SPIII fluid, plus they are even different from each other.
That dealer just wants your money. He must think he is a Mercedes Dealer and that he can charge you those high prices. Those are Mercedes Service Prices.
Those prices & services are absurd ! This is a joke right ? :eek:
Thanks for the feed back. I have not had my car serviced yet as it only has 3050 miles on it. If any Houston drivers have better deals please check in with pricing.
Thanks,
Fiat
Why do you have to go to the dealer for these services? You can go to any local store like Walmart , Sears or even NTB for these jobs. I go to my local Kauffman Tires for all my oil changes for my Honda Odyssey and that costs me $19.99+tax( sometimes even less with coupons).
For my Gennie , I go to the delaer as I negotiated my lease with all these services.I pay $410 each month for my V6 PP gennie which includes oilchange, tire rotation and all the scheduled mantianance.
