How to: Genesis sedan Power mirror gear replacement
Found it, the gear is split/cracked.
exactly what I was about to say. That's what they tend to do. Then just fall apart. My replacement is still working perfect.
This box on top of the motor and gears does not appear to be on correctly. Is there something else that will hold this down? Looks like with a little vibrations and jarring it will pop off and the connection will be gone.
Look at post #52 & #71 in this thread. You have to be sure that the board is plugged/seated correctly. You then need to ensure that the wired plug at the top of the cover also marries to its connection correctly.
I have the mirror on, folding works, the mirror does not move up/down/left/right. I removed the mirror and hear it clicking but no movement of the device that holds the mirror.
Getting back to my mirror, it looks like this is the culprit, anyone familiar with this part. When taking the mirror off it appears this piece separated.
This is the mirror motor, it came apart when I pried the mirror off initially. I broke the tabs getting it off to see how to fix this.
It is held on by the center screw and three tabs around the exterior. It does not look like you can get it back together once it is apart.
I will order another one.
Sorry, I have no experience with tabs breaking or the innards of that part. Good luck finding the part - you may have to find a way to repair it.
I did order one tonight, we will see if I actually get it and how long it takes. It is from a company that had 656 google reviews, 4.5 stars.
Thanks for all you have done.
Since I have some time...
The computer board stayed in the cover, I didn't know it separated, the prongs were bent up so I had to bend them back down and then it fit.
The plastic cover on bottom I was unable to get a razor blade under mine. I drilled a hole and it popped right off, no paint messed up. You could drill a hole the size of a ice pick and it would pop off with an ice pick or similar. If you have difficulties I do recommend the hole.
I will fill hole with black silicone, glue a black plastic backing plate on it or put a plug/grommet in it, not on my list of priorities right now.
On to the next steps.
Now you will need to remove the 4 screws holding the assembly to the cover.
When these are remove the assembly should be loose. I forgot to take a picture but go ahead and disconnect the 2 connectors from behind it. One is for the turn signal and one for the puddle light.
While loose remove this plastic cover too. It will come out from the inside
With the plastic cover now removed you can remove these 3 screws, these will release the motor assembly from the frame work. Be careful not to lose the 2 nuts from the back. To gain access to the screws maneuver the assembly out through the hole in the bottom. I forgot to put screw 2 back in, not sure if its absolutely needed but I will find out.
Once all that is done you should be able to pull the motor out from the frame and take the frame and set it aside.
Now you should be able to make access to the motor and gears. I forgot to take a picture but there is a little plastic cover to take off and move out of the way to gain access to the screws to split the case. The circuitry for the motor is also under this cover, be careful when putting it back on to make sure you get the motor plugged back in. There are 2 pins coming off the board that go into the motor itself to power it.
Once these screws are out carefully pull the casing apart to reveal the gears. replace the gear and reassemble. I would recommend some fresh lithium grease , but if you did a dumb like I did and didn't get any there should be enough in the case to put on the new gear and be fine. Just make sure to scoop some out and apply it to the new gear.
Thats it, I hope this write up helps and isn't too confusing.
Got it!!!
Though I had a hard time getting the cover with the control board back on the motor. The two pins wouldn't fit however I finally got it. I couldn't have done it (as easily) without your post. Thanks!
The new mirror motor came in, BTW the tabs on the motor is what you depress to remove, put new motor in and all works like a charm.
I found a plastic 1/4" plug at Lowes that fits the hole I drilled, there are smaller plugs available. The plastic cover is too thick for the plug to pop in securely so I added glue to the back.
Mine started after I was at a gun show and my guess is one came by and hit the mirror, only a guess. I will be folding my mirrors in now.
I rarely folded in the mirrors, just for car washes, are people hitting the mirrors and breaking the gears or is it old age, comments?
OK, I must say that this was an interesting article. Thank you very much. I am in need to fix the Puddle light. Like you I went to the dealership and the said 900 I asked them if they were allowed to do crack on the job and they looked perplexed. I proceeded to explain that they must be on drugs to ask for such a high price. None the less I am going to do this myself and have been looking for a article like this.
So again thank you very much.
Did the led light die or something?
Just did this to my 2015. There are some variances, but very similar process. Thank you.
I have to do this on a 2015 ..Could you list what the variances are?
we are just owners like you. Re-read the thread and notice posts by 2G owners like yourself. Nobody says anything majorly different.
You are the MAN! just did this and it works perfectly. Followed your steps or I would have never known what to do. Cost $6 for the gear and 2 hours of my time as opposed to buying a mirror assembly from Hyundai for $600. Ha!
do you have a link to buy the gear for $ 6. The original link is for $32 with shipping
I just did this repair and it works better than new. Thanks to all for the info.
Maybe I'm the only one - but I removed all the screws and could not find any way to get to the motor without cutting cables or damaging stuff. I have a 2015 5.0 with no tweeter - and removing it, the mirror, and all the screws was not too hard - yet I see no way to get the motor out. I've read this thread through a few times and viewed all the photos.
Hope I can put it all back together and get it back on - will be working on that the rest of today.
Are there after-market side mirrors that I can purchase in carbon-fiber finish that will work with the blind-spot indicators (I don't care about the memory-feature) that anyone can recommend? Replacing the mirrors would be easy - I figure carbon-fiber finish would match my car better and not have to worry about paint-matching.
