Yeah, a lot of positive reviews who butt dyno and assume that less pedal for same power = more power. All of them, bar none, are clueless about how cars work. Might as well add a splice in MAF "ecu tuner chip" while you're at it to experience all the gains of modern electronics hocus pocus. By the way, I've heard rave reviews about curing people from the flu by bleeding them until near death.
Sprint Booster – Is It Worth It?
[/URL][/URL]
I'm not a skeptic, I'm an automotive electronics technician. You see two wires, I see the entire thoughts of the car going by. There is
nothing you can plug into a throttle pedal wire that will improve power.
Nothing (but you can definitely reduce power). It has 2 or 3 independent but synchronized states that move between a fixed upper and lower limit. There is no way to artificially extend the range by adding electronics.
Fun fact: 100% throttle demand is 88% throttle actuation (give or take 5% depending on engine design). No matter how fast you hit 100% you only get 88% out of it. Engine makes more power by not opening the blade all the way.
