Still haven't pulled the fuses yet but I did some more testing and I don't think any of my options are actually working.
For example I told it i didn't want to use freeways to get to a local store and the first thing it does is tries to get me on to two different freeways yet I could easily get to this store without going on the freeway.
So finally after about 2 miles away from the freeway it stopped telling me to do a legal U-turn and routed me on streets.
Next, I told it I didn't want to use toll roads, and again because there is a toll road running near the store, it tries to have me take the toll until again until I'm about 2 miles away from it.
Now I know it says minize use and not don't use but even Apple maps can route without freeways or toll roads.
So can I ask a favor and see what happens if you ask it not to use a freeway etc. what does it show on your systems, does it take you straight to a freeway or plots a non-freeway route.
Thanks in advance.
It happened exactly the same with me. I figured it most likely because at the end of route options , there is another 2 options fastest route or shortest route, if I choose fastest route, it overrides your settings to avoid toll roads and freeways and makes you go to freeway, but if you choose shortest route then it's guides you through local roads.
Also it might change if for example at the time of input the navigation sees that there is slow traffic at any of available routes , it might redirect you to freeway.
I did the same thing , ignored the navigations suggestions to go trough freeway, and as I was at some point where it see that going to freeway it's not the fastest route , it recalculates and guides me trough local roads.
Sometimes where the local roads and freeways are so close together you really can't see the difference when you check the fastest and shortest routes overview, you really have to zoom in to see where it's going to guide you under each option.
But when I chose the shortest route, it routes me trough local roads, almost every time.
Also when you go deeper after input of destination, and when you do route overview there is another option that you can exclude the roads from the turn by turn overview, you need to click on each road where you see that it's going to direct you on freeway, it then changes the whole route excluding the roads which might force you to go to freeway.
Some times even if you delete those roads which leading you to freeway it might choose next intersection to direct you to freeway, so after the new route overview have to delete those roads as well until there is no more sense for the navigation to direct you to freeway.
I hope you understood the process I am trying to explain
