Use the boost by gear function if you are spinning a little bit on launch. Idk if you are rwd or awd. If rwd enter a value of 4 in the first gear location and that will reduce boost by 4 psi to help not spin
I'm AWD, haven't had any spin with it prepped.
But, last run I just did was 12.499 at 110.15 with a 1.818 60ft.
My R/T was 0.625 tho. So I think I can get down a bit.
But from 12.84 to a 12.49 is a pretty good improvement! I'm pretty happy! Got one more run in about 10-15 as they've closed off the gates.
Don’t worry about reaction time. Take an hour if you need to. I don’t even start my launch sequence until I have a green light. My reactions are usually 3-4 seconds haha. Just focus on your launch and nothing else.
Is cleetus there? Haha. I am waiting so bad to know if he gets ruby into the 7 second range. I’m pretty sure he takes his c6 there to run and it is such a mean car
Not right now afaik but there were some very fast guys out.
My friend with the GTI just handily broke the record for stock turbo, a 12.1 at 117.
I wish I could get that trap speed
Being super light helps out a lot haha
That 12.49 ended up being my best.
Last run the parking brake didn't catch and I rolled a few inches ahead of staging, so I caught that fresh 18 second ET and that nice 11 second 60 foot.
Still trapping around 110. Definitely want to see what FMIC and intake do.
I’ll bet a fmic and Intake will get you another .2 quicker. And if you run a higher map with e30 or race gas that will benefit from those mods when you get them too
This is the best I've got so far. Map 2 with 93oct with up to 10% ethanol, then Boostane in a full tank of gas. Launch control was used. I have intakes similar to AEM.
Rwd I’m assuming?
How much boostane on top of your 93 octane...or rather...what is your final octane ? Using Boostane Pro? Why not Map 3?
Using Map 2 on 93 + boostane is probably overkill (won't hurt)...but really you are primed and ready for Map 3 at this point.
Rwd I’m assuming?
AWD. I’m getting my logs reviewed, looks like I’m getting dips in timing. So one step at a time. Need to figure that out before trying other maps.
You send them in to Terry? It shouldn’t be dropping on map 2 with your set up
he is a smart guy. he will definitely be able to help you out
Yeah and your 0-60 seems on the slow side. I've run multiple 4 flats on Map 2 and 4.1s on Map 1 - AWD mind you..
