Aquineas
4th Genesis
- Mar 9, 2010
- Location
- Georgetown, TX
- Genesis Model Year
- 2020
- Genesis G70
Hey Larry,
On those subframes that cannot fit the collars, the tolerance is so tight, then the bolts are already snug and require no additional collars. The other ones have larger holes, which is why they would require some. Hope this information helps!
Gennie, I bought a set of collars from you and I love them. That being said, please consider becoming an official vendor on this site. That way you are instantly identifiable as a vendor and it helps Sal with the cost of running this place![]()
I have had the rigid collars installed on my Genesis. My mechanic said that the installation took him about 2 hours including an oil change. He felt that the rear had much more play than the front did. He put in 4 in the front and 4 in the rear. He said he had to loosen all the bolts and tighten them all gradually to get the collars to fit. He said the fit was tight. He felt that the rear collars would make more of a difference than the front collars.
He also felt that a rear stabilizer bar would help a lot.
I drove the car for 5-6 miles after the installation. The on center feel of the steering is definitely much better. I only drove on smooth roads, so I am am not sure the effect on the ride.
My mechanic did recommend doing an alignment. The car is going tomorrow to Firestone to have an alignment check done. I will let you know what effect the collars have on the alignment (the car was aligned about 1400 miles ago, so I doubt it has changed much during that time). Firestone gives me a before and after printout, so comparing the before printout to the previous after printout should be interesting.
My mechanic is Jason Rearick from Just Wrenchin' Automotive. It is a 1 man shop. I have used him since 1995. His phone number is 512-423-9923.
Re: Rigid Collar install on my 2015 3.8 Genesis ultimate sedan in NCPlease do since I have the same Genesis as you and am following all this confusing issue with a great amount of interest since I really want to do this mod, but am quite disappointed in the process at this point.
Larry
Had my mechanic do the rigid collar install. He ended up putting the rear 4 Collars on but the front bolt assembly already had frame insert collars that precluded installation of the aluminum Collars. Installation time was less than 1 hour.
So he didn't even put 2 in the front subframe???? All the holes had a built in collar?
I have 2016 v6 ultimate RWD with collars on for almost a week now. The mechanic said, they were able to put all eight of them, 4 in the front and 4 in the back. He did not suggest to have it aligned either. It took them like an hour to do the work.
I kind of feel little bit firm ride, but not too much difference. I had small vibration on the steering wheel at all speed and it is very noticeable in the morning. I will do a wheel balance during the next service. May be an alignment down the road as well.
I don't know, but I suspect when he saw the insert in the front bolts on the front subframe he didn't even look at the back two bolts which on every vehicle so far V6, V8, RWD or AWD all required collars on those back two front sub frame locations. Also, those back two have nuts not bolts and I had to use a bottle jack on the stabilizer bar to lift the sub frame enough to get the collar on and the nut started.
Larry
