The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
Still working on this end as well. Taking car in next week.Still can't fix this issue. Hyudai dealership is not even willing to help. What a pain..
In the Settings for the Car, on the main display. This is your last option on the Right on the Home Screen. You have dig down a bit to get to the right screen. You can modify the Individual Setting and try Comfort or Comfort+ for the Steering Wheel. I think this just boosts the effort, but that might help dampen some of the steering wheel feel. Note, the car defaults to Smart mode each time you start, at least on my 2019.Is there any way I can "numb" my steering wheel? Too much road feel or vibration from my steering wheel.
Hyundai is not willing to help and genesis canada is the same. They(genesis) are kind when I talk to them but not really doing anything to help me.
Thank you very much. I am definitely try that. What about suspension set up? I feel like I should go with sport(or stiff setting.. )Soft setting will give me more jiggly or bumpy feeling.In the Settings for the Car, on the main display. This is your last option on the Right on the Home Screen. You have dig down a bit to get to the right screen. You can modify the Individual Setting and try Comfort or Comfort+ for the Steering Wheel. I think this just boosts the effort, but that might help dampen some of the steering wheel feel. Note, the car defaults to Smart mode each time you start, at least on my 2019.
I just took my car on a 160 mile road trip, averaging 70 to 90MPH, with a brief peak of 120MPH. No issues with the steering. This is a RWD car.
I use Soft setting around town, DFW is rife with Expansive Soils so there are areas where the pavement sucks. And I live in one of them.Thank you very much. I am definitely try that. What about suspension set up? I feel like I should go with sport(or stiff setting.. )Soft setting will give me more jiggly or bumpy feeling.
I drive hwy 80% of time. I will set my suspension to firm and steering to softest setting. Hopefull that makes some changes. I am Korean and lots of koreans(comparing to north americans) drive g90(eq900). I see people having this issue and basically non of them fixed the issue. They have replaced drive shaft, engine mount, tires, rims, and other suspension components. Initially it gets better but eventually vibration comes back. I think this is something to do with body strength.I use Soft setting around town, DFW is rife with Expansive Soils so there are areas where the pavement sucks. And I live in one of them.
But on the Highway, I set to Firm to reduce the floatyness at speed. I kind of wish there were two Individual Settings we could modify, and then set them to be the default.
Interesting theory on the body structure. I have driven high mileage cars that felt solid to me, and a couple that were clearly "rode hard and put away wet" to use a Western UC slang term and they felt fine. My 2013, which weighed like 250 Kilos less had 85,000 on it when I traded and it was smooth and solid, even after driving over some parking lot curbs (I was not paying attention and yes, I was an idiot)I drive hwy 80% of time. I will set my suspension to firm and steering to softest setting. Hopefull that makes some changes. I am Korean and lots of koreans(comparing to north americans) drive g90(eq900). I see people having this issue and basically non of them fixed the issue. They have replaced drive shaft, engine mount, tires, rims, and other suspension components. Initially it gets better but eventually vibration comes back. I think this is something to do with body strength.
It is such a nice car so I do not want to give up but am not sure what else I can try.
Here are some reasons that some vibrations could be caused by the brake rotors:Please excuse my ignorance but how would the rotors have any effect on the vibrations?
Good info - believe another vehicle in the family tree (Kia Stinger) has issues with rotors and vibrations. Not a fan of tire rotation - when car is aligned and balanced well, prefer to leave well enough alone. Appreciate your input and perspective. Happy New Year!Here are some reasons that some vibrations could be caused by the brake rotors:
1. Panic stops can warp the rotors and if they are seriously warped they will set up a vibration as they turn and make contact with the brake pads. The vibration will be more pronounced when applying the brakes.
2. Rotors are a rotating mass and if they are out of balance one could experience vibrations. Eons ago when I was a mechanic we would get the best balance when the when the entire mass of tire, wheel, rotor/drum was spun together on the vehicle.
When I was searching for a used G90 I looked at the carfaxes of at least 50 different cars and I noticed that many of the examples had bent rim repairs. My judgement was that either the rims were easily damaged or the cars were driven on some of the worst roads imaginable.
My G90 had 4-wheel alignment done very early in it's documented history and the tires were never rotated and NEVER will be. Rotating staggered wheels is a no-no in my maintenance plan!
So far my G90 drives and rides smoother than any of my previous 49 cars! Been driving for 65 years, so that is lots of experience talking!
Out of curiosity, what's the issue with rotating staggered wheels?My G90 had 4-wheel alignment done very early in it's documented history and the tires were never rotated and NEVER will be. Rotating staggered wheels is a no-no in my maintenance plan!
Over many years manufacturers have recommended several schemes for tire rotation, front to back, x without spare, x with spare, etc. Because staggered tires can only be exchanged side to side by axle, the rotated tires would be changing rotational direction. Older tires were bias-ply and this method would cause lots of problems with ply separation. Tire manufacturers now claim that modern tires can survive the change in rotation, but for me and my trusted mechanic we do not rotate them and my experience with skipping rotation has been successful. So far, no shimmy or shaking for my G90. I treated my former BMW 750 the same way and had 30,000 miles on staggered Continentals with no problems.Out of curiosity, what's the issue with rotating staggered wheels?
Very interesting. Maybe this explains why the shaking/vibration/wobble symptoms seem to be related to the road surface. On my 2019 3.3T AWD, there is a definite wobble in the steering wheel on smooth surfaces, but the symptom disappears on broken surfaces at highway speeds. I suspect tire condition would also be a factor, but the underlying problem is structural. What a bummer.My G90 also has this similar symptom.
Vibration only appears within a certain speed range indicates the issue is more probably due to the car body's 1st order dynamic torsional rigidity, not tire balancing.
If the tire is unbalanced, then the vibration will become more noticeable after a certain speed, and the higher the speed you go, the more serious the vibration will be. From your description, looks like it is not this case.
For the 1st order dynamic torsional rigidity (which unit is Hz), it is the periodic impact stimulus caused by uneven road surface starting to reach the 1st order natural harmonic frequency of the car frame structure, therefore causes resonance (vibration). When the vehicle speed is too low (or too high), the road impact frequency is far less (or exceed) the resonance frequency, therefore no noticeable vibration; but with the right speed range, the road impact frequency falls in the car body's resonance frequency spectrum, so vibration becomes extraordinary violent to be noticeable.
The vibration depends on the resonance frequency, and also the amplitude; this is totally different than static rigidity. For G90, Genesis only publishes its static rigidity numbers. Not sure how good (or bad) its dynamic rigidity will be.
Look at Car and Driver's review, they also mentioned the following, all in fact are related to the G90's dynamic rigidity properties:
Our 2017 Genesis G90 Soothes, Cossets, and Generally Impresses for 40,000 Miles
"throughout the car's 30,000-mile life so far with us, there's been a mild front-end shimmy that feels like a tire imbalance but isn't."
"The G90 ought to be structurally stiffer, which is especially noticeable as the car accelerates on corrugated surfaces. Imagine, here, a dog shaking water off its back. Of course, when you build a car that is 204.9 inches long, it wants to twist."
I DO rotate them and my experience with rotation has been successful. So far, no shimmy or shaking for my G90. Five years, two set of Contis. So much for anecdotes.we do not rotate them and my experience with skipping rotation has been successful. So far, no shimmy or shaking for my G90.
UpdateVery interesting. Maybe this explains why the shaking/vibration/wobble symptoms seem to be related to the road surface. On my 2019 3.3T AWD, there is a definite wobble in the steering wheel on smooth surfaces, but the symptom disappears on broken surfaces at highway speeds. I suspect tire condition would also be a factor, but the underlying problem is structural. What a bummer.
Assuming that the shimmying is a structural thing, wouldn't it follow that vibrations at this level would result in damage to the frame/suspension/bushings/etc. ?
@moderators is it possible to create a poll for this issue?
