Wheel Bore question
flexstyle
I understand the genesis bore is 67.10 but most wheels I seem to find are just 67.00 .... is it essentially the same thing? or will it not fit?
thank you
Rings are added to wheels that are not quite hub-centric. Aftermarket wheels I have purchased from Tirerack include them for your particular car application.
If a hole is 67mm in diameter, a 67.1mm rod will not fit thru it. Exbmw, you have his question reversed.
Holycrap!! :eek: Bad math or just age-related. Sorry flexstyle. My answer was intended to be helpful.
Thank you for the reply's
So I guess im better off going with 70.50 bore and getting hub centric rings. to 67.10
