PMCErnie
Ancient ‘steemed Member
- Jan 2, 2012
- Location
- Richmond, VA
- Genesis GV70
^ JTREADWAY, you sure have a bunch of gripes. Why not be realistic and weed out the specious ones? For example, if you change your route, your Nav is going to nag you until you CANCEL ROUTE. This problem is of your own making. Your complaint about having to enter the state first in your Nav is equally without merit. That's the way the system works. It is not broken. I don't see a major problem with your Bluetooth streaming connections either. Good luck with the rest of the pile. Maybe someone else here can give you some suggestions.
