HID Lights Retrofit (Standard and Premium Package)
Lawjo1978
Dallas-Fort Worth, Texas
Good Afternoon People,
Has anyone installed any aftermarket HID headlight kits in their Genny’s? If so, how did it work out? Are their any issues after install? What brand is the best?? Let me know........
You cannot just install an HID kit. You will need to either buy factory HID headlights from a Tech Package or a V8 model or buy HID optics and do some fabrication on your end to fit them in your stock headlights.
What year model is it?
I'm not sure whey you say you can't install an aftermarket HID retro kit. I've seen it done very successfully serval times. You'll need to make sure it's wired correctly to avoid flashing, but it works just fine. I've seen 2014/2013 and 2012s retrofitted with after market hid kits.
Scott
Scott
I think what he means is you shouldn't do the HID kit unless it's an actual proper retro fit, not just a plug and play. Plug n Play kits have poor light projection and produce a lot of glare for everyone on the road. So the kit wouldn't benefit you are anyone else.
Scott
I'm not saying you physically can't. I'm saying you shouldn't. HID kits are 50-state illegal and due to trying to mix and match the wrong bulb types with your existing optics you're going to get subpar results. Hot spots and cold spots (uneven light distribution), glare, poor cut off, and the brightest point in the beam won't be where it's supposed to be at the cut off.
