Alwaysforward
- Oct 24, 2013
- Location
- South Florida - Treasure Coast
That is awesome news gameday22...
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
The car was really low on fuel when I picked her up and took 20.1 gallons out of a possible 20.3, It had 21 miles when I left and returned it with 391, took 19.3 gallons to refill it which makes it 19.17mpg.....pretty close.
Did I miss something here? 46 to 47 psi in the tires.Should they not be around 33psi? That is way too much pressure.
how many miles are on the car? that's not very good for a 6.
It would be too much if it were cold pressure, but it's not (so it's not).
Max inflation pressure for these tires is 50psi according to TireRack.
http://www.tirerack.com/tires/tires...r=2015&autoModel=Genesis Sedan&autoModClar=V6
Tire pressure on any car has nothing to do with max pressure rating of the tire. I do not know what the tire pressure recommendation for the new Genesis is but I will assume 33 psi like the older gen. If you want proper tire wear not to mention the best ride handling to go with the car, tire pressure should be taken cold as in not after a ride and at ambient temps which in the case shown should be maybe at 75-80F. That being said, yes the pressure will increase because of the heat which is shown on the display at 98 so add 2 psi and we are now at 33+2=35. Now lets say he came off the interstate after a long run and they were hot (130 degrees) so lets add another 30 degrees to that so now we are at 35+3+38. This is worst case scenario which is probably not the case however even with this reading he is around 9psi over inflated!
Read this. http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=196
This is how the HTRAC and 5.0 both were, we never added any air. I'll go read the tires later today, I don't know what the rating is for them but both cars felt perfectly stable even in a heavy downpour.
I cannot believe I am the only one who noticed the very high pressures? I
Got a laugh out of looking back at the picture of the dash posted previously. This is a good rendering of what the tires would look like at 48 psi form a top view.Wonder if you deflate to normal pressure if the picture changes also.
http://s1021.photobucket.com/user/gameday23/media/2015 Genesis Sedan/20140607_160438.jpg.html
I thought you worked for Tirerack? Car makers' tire inflation recommendations are not on the tire. You can usually find this info on the drivers door jamb, or in the glove compartment, of most cars. Also can be found in the owner's manual.
