Aquineas
4th Genesis
- Mar 9, 2010
- Location
- Georgetown, TX
- Genesis Model Year
- 2020
- Genesis G70
It is NOT engine tuning AND it is not the 3% energy difference between ethanol & gasoline. It is the difference between ethanol engines(using 100% ethanol) & gasoline engines(that should be using 100% gasoline(E0)). Ethanol used(not burned effectively) in low compression ratio(9:1 to 12:1) gasoline engines CANNOT release all its energy, as ethanol burned(effectively) in a high compression ratio(16:1) ethanol engine CAN release all its energy.
Again, ethanol engine engineers are good. Gasoline engine engineers are good. "ethanol in gasoline" propagandists are NOT engineers & NOT good.
Anyhow, pure-gas.org will have listings for 10,000 sources of 100% gasoline(E0) by the beginning of 2016. The "ethanol in gasoline" industry & the EPA can no longer suppress the truth that ethanol is NOT burning effectively in gasoline engines.
This makes a lot more sense to me and seems to support what I and others are seeing in the real world.
