Korean website I found that explains the LED Prada Headlamp install
Bmmotors has lots of good information, well pictures, of modifications that haven't really hit the states yet. Haven't checked out redtune but will have to at home. My work blocks IP's from certain foreign countries.
Two things I am interested in learning more about are:
1. Power open and close trunk.
2. Equus power shades for the rear windows.
I'd love to have a set of the Prada's for my 2010. Current pricing is a bit steeper than I'd be willing to pay however.
_______________________
2010 Satin Pearl White Hyundai Genesis 4.6 w/ Tech Package
-Wings On Trunk\Wheels, Debadged Front
-Dynomax VT Mufflers
-Airbox Flapper Delete
To Do:
-MSA Secondary Cat Deletes
-Rigid Collars
-RSPEC Suspension
-Braided Brake Lines
Previous: 2011 Tsukuba Red Hyundai Genesis Coupe 2.0T RSPEC w/ Tomei M7960 Turbo
I did some research a while back and found that the equus's power trunk part numbers are the exact same as the korean genesis's. However the parts were in the neighborhood of $2000-3000 much more than I'd want to pay for that right now. Have not looked into that rear shades install yet will definitely see if possible.
looks like just switching one wire for the prada conversion?
I'm pretty sure the Genesis Prada has a special AFLS ECU module if you want a direct retrofit. I'll dig it up later when I have the time.
so you think its different than the r-spec one?
Yes please if you could I would appreciate it so much! :)
So what about the cars without the AFLS module? Is that one plug and play? I am sure a lot of us on here want to upgrade to this because we have Halogen headlights.
we need a clarification on the translation. My Korea contacts have no idea. What does that box do, and if we use it do we still need to change the pins? I have the lights so Im ready.
That should be correct. You will not get AFLS settings and it should work plug and play. The changes in the PIN for the headlight is for the AFLS horizontal movement.
That's great news to hear. I can't wait to have the sickest 3.8 in the business....lol.
so wee need the new ecu no matter what? and only re pin if you don't have afls?
Just got a 2011 4.6 and I would LOVE to have these headlights!! I hope this can be PnP.
To clarify
If you do not have AFLS, it's plug and play.
If you have AFLS, you can relocate the pin or purchase the ECU.
AFLS ECU Diagram
