litesong
- Jan 11, 2015
And the FACTS that count are those from repeatable, controlled tests. I have been the ONLY one that has presented FACTS like that on this thread so far.
Yes, you are the only one to present data produced by the EPA/(ethanol in gasoline industry) propagandists. The data NEEDS TO PROVE THE WORTH OF ETHANOL USED IN GASOLINE ENGINES, SO THE EPA/(ethanol in gasoline industry) is proven worthy. & how 'bout dat!!! The propagandist' data proves the worth of ethanol in gasoline engines.
Ethanol engine engineers built high octane, high compression ratio (16:1) ethanol engines to get the most efficiency from 114 octane ethanol. But lo(low) & behold! The EPA/(ethanol in gasoline industry) propagandists get almost the same efficiency out of ethanol, by using low 87 octane, low compression ratio(9:1 to 12:1) gasoline engines. Truly, miraculous events have transpired in the EPA/(ethanol in gasoline industry). Events stating, that high octane high compression ratio ethanol engine engineers only needed to be low octane low compression ratio gasoline engine engineers to make ethanol work right.
It must be tough to be one person against the mob. It must be tough to be a propagandist.
