Just called the Map Center aka Mapnsoft.com. They said they are working on a map update. You'll should be getting a card that will remind you. It's a DVD and you download it to the system. It will require a security code so you can't share it with other owners. The 09 Sonata uses a DVD update and it requires the security code. The 09 Sonata also updates the Software so the Genesis will install that dreaded T-63 update while updating the maps. In the 09 Sonata you do lose your settings when you update the maps. So expect to pay about $200 for the update. Hang in there if you want an updated map. Maybe it will be more up to date. Mapnsoft uses Navteq for their US map database.
