Midnightsun
I just did the third oil change on the car. Just a heads up. The panel inserts (plastic ones) will become almost unusable once taken out so do pick up a bag of 100 or so on eBay and keep in your trunk. http://www.ebay.com/itm/Black-Plast...ash=item566e964550:g:eVYAAOSw9N1Vi50O&vxp=mtr Secondly, the 10mm head bolts holding the balance of the panel in place tend to rust up/jam tight. I sheared off 4 of them and I was very careful. Dunked the remainder in grease and inserted those. Worked half the day drilling out an recapping the frozen ones. What a pita.
This has been mentioned before as the dealerships sort of do not put all of them back in because they are almost unusable as I mentioned. They will shear off the bolts just like I did but not tell you. Bottom line is you will lose your protective panel as the fasteners disappear magically after every oil change and the dealership will deny any fault.
Just a heads up on things to check after an oil change.
