Are these technically the same as the 2015 model in Parking Light mode, which light the headlight LED surrounds? Are the 2016 LED surrounds a brighter LED?
No, they are brighter than the 2015 in parking light mode.
Don't think it will happen. Perhaps if you swap out the Body Control Module where the signal originates and then run a new wire to each DRL - but seems unlikely and/or quite complicated/expensive. I posted details in an earlier thread where I looked up the wiring details on the Hyundai Tech Site:I love that the gears in people's heads are turning. I want the 2016 lights. Hoping an affordable solution pops up from all the brainstorming.
you could always trade in the 2015 for a 2016 ;-)
The DRLs are off if you select Off. You can then do DRL, parking lights, or full headlights (with DRL on too). Fogs come on with full headlights if a secondary switch is toggled on.Just curious.
Since DRL in Canada is mandatory we have no means of turning off the DRL lights. I know in the US on the 2015 model, you guys had a switch on the stalk which you could select on or off. Did they keep this switch intact on the 2016 with the new DRL's or did they take easy street and just drop in the Canadian version.
That would mean that US drivers could have LED DRLs by turning off the DRLs and wiring in the LED parking lamps to the key switch, correct?
It is not the same as turning on the parking lights. The parking lights will run the tail lights as well. I also want the headlights to operate automatically. If I turn on the parking lights, that would not work. The idea is that the wire to the LED parking lights would be cut and the power source for the LEDs would be a wire controlled by the key switch.
Hopefully if you can afford a Genesis you afford a light bulb
