Jetjockey10
- Dec 1, 2015
Just wondering if this is on both the V8 and the Ultimate Optioned v6 rwd.
Thanks.
Ray
Thanks.
Ray
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
Did you check the feature list on the Hyundai website?Just wondering if this is on both the V8 and the Ultimate Optioned v6 rwd.
Thanks.
Ray
Thanks.
Ray
Only on the V8 and only on the front door sills. However, you can have them installed on a V6 by the dealer as an accessory - or buy the sills and do it yourself (you can buy as an OEM kit).
So do your think that I knew the answer and deliberately did not tell you?I did check the website but only found 2016 info. Thanks for not answering.
Ray
I seem to recall that lighted sills cannot be installed easily in some Gen 2 models. Something to do with lacking the needed wiring harness and no connector plugs under the sill plates. No such problems with 1 Gen models.
The G1 input is irrelevant as the OP clearly stated he was asking about 2015 G2 in the title of the thread?
With respect to the ease of installation on the G2, I wouldn't call it hard, but you do need to thread the leads from the driver side sill plate through the dashboard to under the glove box to make the power connections. It will take some time and patience to do, but not technically difficult.
I'll decide what is relevant in my posts, thank you very much. It's a breeze to install the lighted sill plates in the Gen 1 cars. They are plug and play. Not so easy in the improved Gen 2 vehicles.
Strange that you did not mention the extra difficulties of installing them until I mentioned it above. Is there anything else you need to tell the OP? I'll defer to your expertise.
Again, why are people posting questions about the Gen1 in the Gen2 section? It just leads to confusion in the end as is evident above. This post should be deleted and reposted in the proper section IMHO.
In this case, the OP's question was about his G2, so it was in the right forum - it was the response about the G1 that threw us a little bit off course.![]()
Use the trunk monkey option on him.Again, why are people posting questions about the Gen1 in the Gen2 section? It just leads to confusion in the end as is evident above. This post should be deleted and reposted in the proper section IMHO.
Ray, please let us know how easy this upgrade is. The Gen 1 upgrade to lighted sills is a breeze. Takes 10 minutes for two sills.
You have to wonder why some folks are so caught up in their own thing that they cannot stand to discuss the big picture of the Genesis. If ya wanna get picky, this thread should have been posted in the Lighting & Appearance Mod forum, not the '15 forum.
No, I did not know the answer, but I knew where you could get it.Yes, that is the way I read your reply. No problem though. I have my answer.
Ray
Yes, he mentioned that later and I did not think of that when I first posted. I probably would have looked at the 2016 features anyway, as they are mostly the same.I don't think you were trying to withhold info from the OP - but the 2015 model info was already purged from the Hyundai website some time ago, so there was no feature list info there for him to check.
