We Brought the Korean version of Full LED HID lights
Uchiha madara: Did your car already have LED DRLs with the stock lights?
The problems with the DRLs when changing the lights on the 2015 USA version are because it originally came with halogen DRLs and uses different wiring harnesses (and possibly BCM changes). If his car already had LED DRLs, then the DRLs on the new ones probably work without any changes.
about the USA version of genesis 2015 it cant work
because you DRLs is not LED so wiring is different
in USA version of genesis 2016 its equip with Stock DRLs LED
the Full LED system can work with the USA Genesis 2016 only
You should be more clear to everyone that you have a Middle East version of Genesis, and not USA version.
Also I'm guessing these won't turn with steering wheel input? Adaptive headlamps are so nice
every knows that im in saudi arabia :)
but there is not much different in most of our features
specially in the lights we have single projector with DRL stock exactly like your 2016 version and your G80
I disagree.
but there is not much different in most of our features specially in the lights we have single projector with DRL stock exactly like your 2016 version and your G80
Disagree again. $2100 is a lot of money to waste on something that doesn't work correctly.
I disagree.
i said it before its kind of expensive but it worth it
only one function is not working and i think its from the lighting computer
i will buy it and change it then i will see
I am not trying to tell anyone whether it is worth it, assuming it actually works. My concern is that it may not work on USA Genesis cars, and that people need to understand that before jumping in.
it worked in saudi arabia and it should work in USA
either way i have downloaded the manual repair guide that made by the factory and i found that the wiring diagram is the system as in saudi arabia
so im sure until now that it gonna work
either way i will post the video and pics of the wiring
...post #7 pretty much established that?
the prices from korea to Saudi Arabia totally is 7900 SAR that means 2100 $
its kind expensive but it deserve it and that is Genuine part
I'm sure it will light up.
I don't think its 'adaptive / curving' headlights won't work since older cars are missing a module or two for it.
Last time I heard shops in Korea are working to find a solution for those who want that feature working on 'Hyundai Genesis' as opposed to 'Genesis G80'.
it goes up and down automatically like the same you have in your car
but turning left or right viewing lights are not on we dont know how to enable it as we think that its about the computer
Here in USA that was a standard feature in the 1G Tech but it was eliminated in 2G.
it goes up and down depending on the nose of the car is going up or down
it will work with you because there is sensor for that it works in USA version im sure
im talking about the original one that it comes stock with the car
Don't assume that.
It requires a separate ALFS module for that which 2015~2016 lack.
Don't assume that.
I think he means the basic auto-leveling feature that the HID's in the 2015/2016 has will still work with the KDM LED's I believe that only happens at start up and is not a dynamic feature like the full blown ALFS?
I think our 2Gs have autoleveling, moving up or down according to the car's weight distribution but they lack of vertical movement when cornering like the 1G with ALFS. I still miss the "light dancing" that my 1G used to do when starting.
