We Brought the Korean version of Full LED HID lights
Dat5.0GenLyfe2016
AUTHORIZED VENDOR
238
22
CarlitoGR
62
13
Maryland
is this the harness that your referring to from sharkracing.com
Dat5.0GenLyfe2016
AUTHORIZED VENDOR
238
22
Dat5.0GenLyfe2016
AUTHORIZED VENDOR
238
22
Gprime
So will the KDM led work on 2015 Genesis basic model with no option? I need my drl is orange/yellow and it does not have HID but only halogen. Do anyone know it will still work with my genesis?
g_969314
I brought the Korean lights. When on auto my DRL are amber and they flicker. can someone tell me how to correct the problem
kolme
64
5
Texas
yup mine does the same thing, not sure why it does that.. seems to have some voltage issues,
Hey!
Thanks for pitching in about these lights for last few months. I wanted to get some quick clarification as I am thinking about buying a pair.
1. Do the lights fit without physical mods?
2. When plugged in using the Korean wiring harness; the low beam, high beams, and DRL function work correctly when NOT on auto?
3. The LED turn signal works with the harness, however it does not have its sequential feature?
4. Lastly, since these lights are adaptive, are there issues with the lights getting out of alignment??
Thanks!!!
Kolme
CarlitoGR
62
13
Maryland
So I purchased the lights and put a relay between the DRL and Turn Signal with a 3333μF capacitor across power and ground. I also have a modified wire harness that repinned the power and grounds to high beam, and other functions to the various related LED pins. I haven't finished this mod yet, been so busy at work and reserves but I will eventually have a finished product.
Here's the link to the thread I posted about it: HID to LED Headlight Conversion
cRaCkZzZz
Hello CarlitoGR,
Any update for your mod? I'm also interested to install those LED headlights on 2015 Gen. Could you please share a wiring diagram?
I found an adapter in Korea and seller told me that it should work for converting 13 pin (Bixenon) to 14 (LED). But this adapter is looks similar to yours which you bought from sharkracing.com.
Dat5.0GenLyfe2016
AUTHORIZED VENDOR
238
22
