I just tried to install my kit...not a fun job, mostly from trying to jack up the car and get it steady. I jacked up the rear using the subframe to suspension pivot point, then put the stands under the normal jack points. I then kept the subframe supported by putting the jack on its cross member, behind the diff, and kept some tension on it. I think that helped keep everything in alignment and I had no issues putting in the
collars and getting the bolts/nuts back on. And then horrors of horrors, to remove the stands I just jacked up the rear using the 1 subframe point till the stands cleared and quickly lowered it
But then the front.... I jacked up one corner by the correct jack point and then put a stand under a solid subframe point. I was amazed that when I let the jack go the other front corner lifted off the ground...stiff frame! I then used the other corner subframe point to jack up the other corner and put the stand under the correct jack point. So at this point I had 1 stand on the body and 1 on the subframe. I decided to take a look at the bolts to figure out if I needed to support it by the jack point, but I never got that far. The 2 supplied
collars are the correct outside diameter, but too small internally to let the bolt pass. And my bolts didn't have the plastic spacers indicated in the instructions. For grins I pulled the front bolts and there is no built in collar, there is a nice gap and it should get
collars as well. Not sure what car Tomi used to size out these
collars, was it an Ultimate that has the electronic shocks? Maybe they are different... I got hold of Tomi and he is going to send me the parts I need.
So for all of you thinking of doing this, I would pull the front subframe bolts and verify what you have! I will say that especially in the front, I can see where all that play could mess the suspension up. I look forward to getting this Beta test over and seeing how she drives. I am less sure about the rear
collars as they go into aluminum "slugs" that are isolated from the remaining subframe by rubber. But I guess everything counts...
