rrtetrault
So what is the solution to changing the amber surround to a white surround? Ive been looking thru here for a while and may have missed it
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
That's the thread - my result using this is on page 4 or so. I had a guy do it, as i was not interested in removing the front fender. The pics on page 2 are correct and detail what is needed once the fender if off.
Same wiring harness. Different headlights setup as shown in the owners manual. Version A or version B.Different wiring harness - the USA 2015's send the DRL signal down the turn signal wire and there is no wire in the DRL pin position in the connector.
Same wiring. Two types of headlights as listed in your owners manual...as an option maybeI would love to know what the genius who decided to have the US and Canadian spec cars be different was thinking.
Unless there is a law in the US that makes the 2015 US setup a legal requirement, this is breathtakingly stupid from a logistical perspective (now you have to manufacture several different wiring harnesses, stock two different wiring harnesses in North America, include different repair instructions for two North American markets, etc.) as well as from an aesthetic point of view.
I just checked a few European websites as well, and the Genesis uses the LED surrounds there as DLR as well. It looks like they may have changed that for the 2016 model, but why do this for the 2015's?
Doing that will turn your rear tail lights on aswellam i missing something? why don't you just leave your full time lights on if those last longer than the drl's? Else can you get a LED bulb that lasts much longer for the DRL amber light?
1156 led white/amber switchback canbus bulbs are the solution. there are only two wires going in the socket instead of 3 like an 1157 bulb would require. originally there's an 1157 bulb in there, working only half. widen the bottom of the 1156 bulb with a soldering gun to touch the contact and shave a bit the notch on the side of the bulb so it'll fit in the socket. it would not fall off. This will do it: 2X 1156 BAU15S 60SMD LED Canbus Switchback White DRL & Amber Turn Signal Light | eBayDoing that will turn your rear tail lights on aswell
