Mr. Incredible
G80 gone, still a Hyundai owner. 2021 Palisade
- Jun 6, 2018
- Genesis Model Year
- 2018
- Genesis G80 Sport
Then you are going to have to set them with your memory buttons in the driver door. On the G80 there are two buttons on the door panel along with a memory button. Set your desired positions then press the memory button and the number you choose 1 or 2. The next time you seat yourself in the vehicle press the same number and you will be positioned in the proper settings. The FOB doesn't have any capacity to remember these settings. The seating, mirror, steering wheel positions are directly connected with the buttons located on the drivers door. There is no pairing the Key Fob.
Actually no, you have control over what you decide to do. Just attempting to give you options, help and suggestions. The reason you can't find it in the manual; what you are asking for after you explained your purpose and intent doesn't exist, unless it is completely different from other 2018/19 Genesis automobiles.
Have a wonderful day!
also the G80 (can't speak for the G70 so hopefully someone can chime in) will remember the last setting used when you exit, so if you press the Memory 1 and drive, then some knuckle mechanic comes along and moves your seat, it will not reset to memory 1, it will remember the last position, so you will have to press memory 1 again to get your settings back, but if there is no change between the time you turn off and restart the car it should always stay in the last used settings.
. Here, you can look here for yourself;
