Man and I really like the grille on the G70 compared to the Stinger. Not that the Kia is bad but I prefer the size on the G70 versus the karp mouth look.
Tiger nose man. Get it right 😋
I'm just not a fan of the over aggressive grill trend started by Ford and carried over into Lexus with the predator styles.
https://motorillustrated.com/wp-con...70-3.3T-vs-2018-Kia-Stinger-GT-Limited-66.jpg
I still agree that the G70 is a much better looking car but I do certain aspects of the stinger better. The door handles, grill, rear proportions of the stinger are great. But everything else on the G70 is just done better especially the paint.
https://st.motortrend.com/uploads/sites/5/2017/09/2018-Kia-Stinger-2019-Genesis-G70.jpg
https://i.ytimg.com/vi/Ierz4KjXr_k/maxresdefault.jpg
I appreciate the body styling on the Stinger to be clear, hood vent applique aside. The rear 'haunches' on both cars are great, I like the aggressive hips that they have, reminds me of my 96 Cobra that has similar very pronounced strong rear 3rd. And it's not that I don't like the Stinger grille, I just prefer the bigger one. To me it suggests performance I guess.
The cold the last few weeks has me really irritated by the lack of seat heaters on the app when starting the car. The seats are ice cold and hard as a rock after work even after running for 10+ minutes.
On the plus side in this weather the car stays really clean after a wash!
Yes! That's one thing I wish they'd add. I mean they added the steering wheel and rear defrost. It must be fairly simple to add? I thought the same thing back to my sonata limited when I used the blue link app. Would put it over the edge I feel.
Only car I had that I could put the seats on was my 2010 Sonata. I could hit the switch beforehand and it would stay on.
I've felt the jerkiness during downshifts when coasting to a stop in Sport mode but it's hardly perceptible in comfort mode. I feel it was added intentionally to make it feel sportier which I appreciate. For a smoother luxury sedan with less sportiness an A4 would be an ok pick. A bit boring but a perfectly good daily driver.
The electronics just aren't blipping up the engine revs when downshifting... sounds like their rev-matching program only gets about halfway... so there's still a slight engine-braking effect. Ideally (IMO), it would rev a little higher and reduce the 'jerkiness' (even in Sport mode).
Well the simple factory key fob starter on my Jeep Grand Cherokee is smart enough to turn on the seat heaters when the temp is below zero (not sure the exact temp) and the a/c seats when the temp is about 20 or so.
And every Ford starter for the last 5 plus years can as well, plus their app. Just seems like a no brainer and something I just think there is no excuse for Genesis not to have.
Auto tilt down (not sure what to call it) where you put the car in reverse and the side view mirrors tilt downward is only available if you have the mirror switch in the non neutral setting. just a weird quirk, and I just found out we had it today!
Also, I wish there was a verbal chime to confirm all doors unlock vs just the one unlock. You can double click to unlock all but as far as I know the chime is the same for both. Has resulted in many times where my fiancé tries to open the door and I didn’t realize until I was in the car and she was yanking on the handle that it didn’t take my double click unlock command
And you don't like having that feature?
I like it, just weird that it only works with the switch in a non neutral setting. I’m the kind of guy that likes to leave it in neutral so I don’t accidentally hit it but it’s just a quirk I wanted to point out. Not a big deal at all to leave the switch on the left or right side
I hated the double press unlock feature in my past Genesis so I disabled it straight away on my G70. Unless you live in a dangerous area I'd recommend disabling the double press unlock, saved a lot of frustration for both my wife and I as you open all 4 doors with a single press.
Oh, I understand.
Actually not as weird as you might think. For the folks that don’t want the mirrors to ever tilt (I rarely if ever use the tilt) they had to pick some position and they chose the center one.
I can't remember if this is normal behavior or not anymore. Should you be able to roll up windows while on accessory power? Sometimes I'll be waiting for some friends to show up somewhere and I like to sit with the car off and windows down. But the only way I can roll them up is if I turn on the car? Is that normal on cars?
I think you can roll them up...but only before X number of seconds...or before anyone opens a door.
To elaborate onBeefer’s response:
The Engine Start/Stop button must be in the ON position to be able to raise or lower the windows. Each door has a Power Window switch to control that door's window. The driver has a Power Window Lock switch which can block the operation of pas- senger windows. The power windows will operate for approximately 30 seconds after the Engine Start/Stop button is in the OFF position.
However, if the front doors are opened, the Power Windows cannot be operated even within the 30 second period.
