First Generation 2014 R-spec 5.0 BTR TCU and ECU dyno results
Post #40 in this thread he has pics posted
I have 275/30 on storm lowering springs.. and honestly next time around I'm gonna go 305 its damn near perfect fitment if your offsets are right and you have no poke there should be no rub.
Here are some pics to show you what 275 looks like on a 20x10 +40 offset in comparison to his set up
See I do have poke though. Currently I'm running 245/35 stretched on 10.5" x 19" wheels all around. The offset puts them slightly past the wheel well and I have -1.4 degrees camber on that side. They dont rub at all and I have ARK GTS Springs but it's still got a decent gap in the back as they didnt lower as much as expected. Still not sure about running that wide but let me get some pics of mine so you can see what I mean
Aye reps or not they look damn good on this car! also what exhaust tips are those? what size? damn near exactly how i wanted to do my set up when i get around to putting on the magnaflow..
yeah see i dont know if kmann is on stock suspension or not.. if he is and hes rubbing youd for sure get some being that youre lowered on springs
I'll have to get back to you on that one lol I dont remember the exact brand of the tips. Let me do some research. But the whole exhaust is custom from 2ndary cat delete back
But damn man!!! That blue!! I've been thinking about getting a wrap in a similar color but wast sure how it would look on this model car. Looks great!
And thanks brother i appreciate it. This was done using spray wrap pro and autoflex coatings basically professional version of plastidip. its wet sand and buffable i just havent got around to doing it yet lol
Please do! caus that look and fitment is killer. id just throw on the magnaflow cat back with test pipes and then change the tips out to quads instead of our current bumper slots lol
Follow my Instagram @greasy5.0 for more pictures and videos.
Are you on Storm's in these pics? How do they ride?
*I wish there was trans tuning for the ZF...
Dope shot.
No I'm still getting it at any speed in manual mode for example 40 mph it jerks in second gear the only way I can stop it is to up shift to the next gear. It will do this at any constant speed below 80 mph. So if your driving let say 60mph and your just cruising it will jerk it worse in lower gears. I hope you understand what I'm trying to relay to you.
Is trying ti nils rpm
Yeah and they ride amazing drop looks great I have a 3.8 so a 5.0 would drop even a bit more I'm sure I think storms drop the rear more than arks do. I'm going to be replacing shocks soon when I do my brake swap, with OEM r spec ones should stiffen things up even more..
Would you be able to use front springs from ark and rear springs from storm together?
