ephone1
- Apr 21, 2019
- Location
- West Michigan
- Genesis G70
Has anyone tapped the power from the mirror to power a radar detector?
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
i would appreciate that, thanks! something i have in mind for when i pull the trigger.Yes to the ignition power wire so the radar detector turns on when the car is on. Do you need a picture of which wire is positive and which wire is ground?
Might be better off running the wire tucked in the headliner to the A pillar then down to the fuse panel, use a fuse tap.
I put my detector in the lower left above the reg sticker, real tidy.
What detector are you using?
My last one started to prove useless, and I had it tapped into me Genny mirror. F***** lasers.
There is... just run it beside itIs there an airbag in the A-Pillar?
Yes. Here is the wiring diagram.
I used pin 8 for the ground and pin 6 for the power. That way it will turn off when I turn the car off.What pins did you tap?
I see pin 8 is ground... is that what you used?
Which one did you tap for positive?
Perfect. Thanks!I used pin 8 for the ground and pin 6 for the power. That way it will turn off when I turn the car off.
I inserted them in the back of the female connector.Where did you insert the prongs for the tap? Inserted into the female side of the connection where both male and female connections come together? Or, in the back of the female connector?
Thanks.
