All I want to know is does the Sprint Booster completely override the throttle cutoff that you get when flooring it and having the rear wheels spin (I'm not talking about the esc problem). I am told that Hyundia programmed the tcu to only open to 40% max regardless of full throttle pedal position until about 30-40 mph and if full throttle is attempted the tcu basically partially shuts down the engine until over that mph. Which is why some feel as though their heads will hit the steering wheel as the engine takes off then is starved, then almost immediately picks up only to possibily starve again until the tcu allows full opening. If the SB solves this design interference, then I will be a buyer and forget about feathering the pedal like a ballet dancer through that range.
I believe so. However, I can not be certain since I do not know what is going on with the throttle body electrical signal with the Sprint Booster.All I want to know is does the Sprint Booster completely override the throttle cutoff that you get when flooring it and having the rear wheels spin (I'm not talking about the esc problem). I am told that Hyundia programmed the tcu to only open to 40% max regardless of full throttle pedal position until about 30-40 mph and if full throttle is attempted the tcu basically partially shuts down the engine until over that mph. Which is why some feel as though their heads will hit the steering wheel as the engine takes off then is starved, then almost immediately picks up only to possibily starve again until the tcu allows full opening. If the SB solves this design interference, then I will be a buyer and forget about feathering the pedal like a ballet dancer through that range.
Fyi you can get the same thing from BTR for a lot less money.. just saying.After putting some miles and more usage with the Sprint Booster I decided that I may have had the settings too high. I was using the Sprint Booster in race mode with a level 9 setting which is good for straight acceleration runs, but not when engine braking and feathering the throttle around curves. The level 9 setting gives too much of a voltage signal to the throttle system which seems to make the system think it need full throttle with every press of the gas pedal.
I have decided to just use race mode setting 1 on the Sprint Booster for my Genesis. The drive-by wire system seem to be happier with that setting(less surging and down shifting confusion) and it is easier to drive the car with that setting overall. The level 9 setting is best used when you want to dust a fast car in a straight line such as at a drag strip.
Just my latest observation.
No, I can not.Fyi you can get the same thing from BTR for a lot less money.. just saying.![]()
The pic says $179 for a no name pedal tuner not $79. Sprint Booster is well known product name and reliable. However, the BMS tuner would probably do the same job as the Sprint Booster.Google is your friend.. were talking about a pedal tuner here man?? You can get them on ebay for $70..View attachment 20126
To sum it up , yes.^^^ So are you effectively saying that with the sprint booster installed, you are get 100% open throttle at only 50% pedal (and anything beyond 50% pedal has no further influence), and that without the sprint booster the max. throttle opening is 86%? So the sprint booster actually creates more power?
I think this may be what happened to me the other day.The engine power is raw and hard to control with the Sprint Booster, but it does make the Genesis very fun to drive and much more competitive if I remember not to floor the gas pedal. I have learned to just press the pedal half way with the Sprint Booster and the car moves like it is supercharged. If I press the pedal all the way down the engine bogs due to the throttle plate closing even at speed due to the kick-down.
I first thought it was the traction/stability control reducing power, but learned it is the kick-down reducing the throttle opening back to 86% from 98% when I stomped the pedal.
If I am understanding you correctly, as long as you push the gas pedal to 50%+, but not all the way down, is where you get the best performance? Because this would go around the kick-down, while at the same time giving you a throttle that opens 12% more? If this is true, than you may have finally made my mind of up for me.To sum it up , yes.
The only way to get full throttle without the Sprint Booster module would be to press the gas pedal all the way down, however doing so will activate the kick-down switch which limits the throttle opening to 86%. The Sprint Booster allows the throttle to open to 98%(mechanical limit per specs) due to manipulating the voltage in such a way that the system fully opens the throttle at only half pedal travel well before the kick-down switch is activated.
Therefore, the engine is actually making more power due to more air being allowed to enter the throttle body in theory as opposed to the stock kick-down power level limited to 86% throttle. 86% throttle vs. 98% throttle opening. How much power is gained from a 12% throttle opening is anyone guess, but a gain is a gain.
Yes, it does for me. And, like carguy75 says, you have to "remember not to floor the gas pedal"So the question is, does the car accelerate better, at any speed, without the kick-down feature engaged?
If you combine this method with the Sprint Booster, then you are getting maximum acceleration with a 12% increase in how open the throttle is, correct?Yes, it does for me. And, like carguy75 says, you have to "remember not to floor the gas pedal"
Jalvin,If you combine this method with the Sprint Booster, then you are getting maximum acceleration with a 12% increase in how open the throttle is, correct?
