carguy75
- Jun 23, 2018
- Location
- Atlanta, Georgia
- Genesis Model Year
- 2015
Precisely.Someone correct me if I am wrong, but I want to make sure I understand correctly.
To reach 98% open throttle WITHOUT Sprint Booster, you have to press the gas all the way down WITHOUT activating the kick down. This is difficult because 100% full throttle and the kick down switch are very close to each other, so you would have to get incredibly good at pressing the gas pedal all the way down, but without activating the kick down. This means you actually aren't pushing the pedal all the way down, but 99% of the way down.
To reach 98% open throttle WITH Sprint Booster, all you have to do is push the gas pedal down in the 50-99% range, since full throttle is at 50%. This is much easier to achieve with the additional room you have in the second half of the pedal. This means that the Sprint Booster makes it easier for drivers to get a wide open throttle without activating the kick down.
If the 2 paragraphs above are true, I may be ordering one myself. I have the base model 2012 3.8 sedan, which did not come standard with driver modes like Eco, Sport. etc... That benefit, along with the Valet and Lock mode, AND the easier access to the 98% open throttle, would make the purchase totally worth it.
Your understanding of how the Sprint Booster helps with reducing the time to reach full throttle is correct.
So, overall the Sprint Booster just reduces the time it takes to reach full throttle which is about a few 1/10ths of a second depending on the driver foot speed and ability not to the press the kick down switch in the process which would add time to the overall 0-60mph.
